Don’t forget to tighten your driver screws
BlueFox
BlueFox Posts: 15,251
It’s that time of the year to check your drivers, and make sure the screws haven’t loosened over the past year. Just did mine. Interestingly, a couple of screws on both tweeters took a very slight turn, while the mids and woofers were still good. Now I can enjoy the tunes for another year. :)
    nooshinjohn Posts: 25,918
    edited June 2018
    BlueFox wrote: »
    We have known you had a few loose screws for a while now...
  • BlueFox
    LOL. I was waiting for that. :)
    Sorry to have kept you waiting Mr. Fox :p
  • BlueFox
    No problem. I realize you are slow. :)
    mhardy6647 Posts: 35,011
    FWIW: I use Jennifer Warnes' Way Down Deep to check for loose screws (or other bits) on loudspeakers.
  • steveinaz
    steveinaz Posts: 19,545
    True stuff. You'd be amazed how much these screws can back out.
