On the Fence: iPhone 8 Plus or X
  • mlistens03
    mlistens03 Posts: 2,767
    iOS 12 is gonna speed up that old iPhone significantly if you can hold out that long. There aren’t a ton of new headline features but significant work was done around performance and speeding up older devices in particular. Everything back to the iPhone 5S will get iOS 12, so that covers back to 2013.
    Wait, will this be for iPads and IPods as well??
    If so, I can forget about buying a new tablet! My current one is having display problems and battery problems from time to time, and since it was so old and slow I was just gonna buy a new one, but if they are gonna do that, I’ll just get a new battery and display!
    Also, do you happen to know the cause of the lines across the display on the iPad mini 2?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    Yes it’s for iPads as well back to the iPad Mini 2. Basically if you’re running iOS 11 now you’ll be able to run iOS 12.
    No ideas on the lines on your iPad unfortunately.
  • mlistens03
    I think the display is failing, because when I take a screen shot while it is happening it isn’t there. If IOS 12 does speed it up I’ll get a new display and be done with it. If you wanna see what I’m talking about, you can probably google iPad lines on display, it seems to be a relatively common problem.
  • mlistens03
    Not my iPad, but same problem.
    EndersShadow Posts: 17,719
    edited June 2018
    I plan to hold out till at least the new iPhone hardware refresh is revealed later this year, to see what that may change.
    So iOS12 should be out in the wild by then.
    edited August 2018
    So my iPhone 6 Plus bit the dust yesterday. Its exhibiting the touch id logic chip failure where it wont recognize when I touch the screen and I get a weird white bar across the top of the screen. It goes in and out occasionally recognizing my touches but its like at 10% working max.
    So I'm limping through the week without a working phone and buying the iPhone 8 Plus this weekend as I can't wait any longer.
    I also dont want to shell out another 150 to repair it (unless @AsSiMiLaTeD knows something I dont about out of warranty repairs for this specific issue) just to replace it later this year. Otherwise my phone is in perfect condition but too bad its worth nothing now.
    txcoastal1 Posts: 13,519
    Yikes that suux.
    I'm sorry I made the battery bandaid suggestion
    I will more than likely still be getting the latest Iphone October'ish pending on review
    good luck pal
    txcoastal1 wrote: »
    Yikes that suux.
    good luck pal
    No worries, the battery helped, as did installing iOS 12. The logic board failure is a known issue with iPhone 6 Plus's, however since mine was so well taken care of it didnt show up until now (from what I'm reading its a cold solder issue).
    pitdogg2 Posts: 27,238
    Stick it in the oven....
    Yeah, with my luck I'd break the oven too......
    Dan---"Watch this and hold my wine cooler"...lol
    txcoastal1 wrote: »
    Punk.... I'm drinking Smirnoff Vodka straight tonight lol.....
    I'm gonna regret it tomorrow for sure, likely in another hour.....
    Intestinal inflammation makes drinking not too much fun......
    But I do it anyway.... just ask Russ @lightman1 and Ryan @ZLTFUL :smile:
  • lightman1
    lightman1 Posts: 10,797
    Dude can hold his own in hard ciders.....
    edited August 2018
    lightman1 wrote: »
    Alcopop's is what they really are.
  • alucididea
    alucididea Posts: 113
    After having a 6 Plus and then moving to the X, the X is a much better sized phone. I went to pick up an 8 Plus at a store the other day, and I honesty can’t believe I ever had anything that big in my pocket (and I never had a case on it for 2 years). Not to mention those two BIG panes of glass end up being super heavy.
    I picked up the X in December, and I notice the battery life increase. Seems the oled screen makes a serious improvement. The screen size/phone size ratio is way better. I was hesitant of the facial recognition, though it seems to work quite well. Every now and then it can glitch, but that was always my experience with the Touch ID as well so I don’t see that as an intrinsic negative. I usually only have problems with it when I have my sunglasses on. So it’s hard to complain...
  • My two girls got iphone x's for xmas. This is the first device they have EVER owned that they have never asked me to "fix". That happens with anything they have ever owned more times than I can tell. Happens EVERY SINGLE DAY when my daughter calls me from her bedroom to let me know I need to "fix" the internet!!!
  • mlistens03
    Ronster267 wrote: »
    I have sisters like this. I get asked to fix tablets, WiFi, computers, toys, anything and everything. You name it I probably have fixed it.
    Well, got the X... because the 8 Plus 256gig was sold out when we went to get it. I couldn't wait for their shipment to come in (7+ days) so we just got the X (256 gig).
    Got a Otterbox defender case (for now), and a screen protector. Will likely be getting something a little less thick than the defender in the next few, but wanted something to protect it in the meantime.
    So far I've liked it.... A LOT. Its smaller than my 6 Plus but the screen size isnt really that much smaller.... Face ID is nice and has worked quite well. The phone seems liek its 4x faster than what I had. I also like that the screen seems a lot nicer than my 6Plus. And I can record video in 4K (if I want to).
    Anyway so far, I'm liking it better than my 6 Plus, but time will tell.
  • AsSiMiLaTeD
    If you haven’t done anything with the 6 Plus it’s worth taking in to the Apple store. You’ve got a 50/50 shot of catching them on a slow day and they will often repair out of warranty items for free.
    I use a Kavaj case on my X, holds two cards and as a result I haven’t carried a wallet in years.
    edited August 2018
    Its in about as good a condition as you can get being in a IP7 rated case from the moment I got it, so if its salvageable I'd like to hold onto it. My goal was to eventually just use it as a REALLY REALLY large iPod and leave it in my car 24/7, and also as a backup in case my wife or my MIL or FIL broke their iPhones, they could just use this one instead of buying a new one.
    I will make a trip up that way at some point, just have to plan it as its about an hour from my house or 45 mins from my work one way..
    Will take a look at that case. I unfortunately need to have a lot of cards on me, mostly for my doctors, so I'm still going to need a wallet either way.
    So far still digging my X and I've been playing with it a lot today.
    Dan
    Does your wife know what you have been doing...TMI...imho
    txcoastal1 wrote: »
    Dan
    HAHAHAHA..... I just introduced her to the animoji's.........
    edited August 2018
    txcoastal1 wrote: »
    Dan
    You sick demented twisted mucker pucker. LOL
  • scubalab
    scubalab Posts: 3,105
    Oh Dan... I'm surprised Ron & Ivan were the only ones to have fun at your expense with this one so far!
    I've got too many - I'll just let the imagination run wild.
    edited August 2018
    scubalab wrote: »
    So you enjoy picturing that huh..... whats that say about you :wink:
    #burn
