Cooling fans work/ help?
Kingkwas
Kingkwas Posts: 92
edited May 2018 in Electronics
Do cooling fans help increase performance?
https://www.amazon.com/AC-Infinity-Top-Exhaust-Receivers-Components/dp/B01LW1Q4X9
Played Fury tonight on a 4k disc. Swear that by the end it didn’t sound as good. Less punch. Afterwards when taking out the DVD, the Marantz was hot to touch.
Thoughts?
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
  • BlueFox
    BlueFox Posts: 15,251
    edited May 2018
    Excess heat is the enemy of electronics. I doubt if the fan will hurt, and might help. The issue I have with cooling fans is my hearing is pretty good, and the fan noise between songs, or in quiet passages really annoyed me.
    EndersShadow Posts: 17,705
    edited May 2018
    I have two of these, both S8s. One on top my Denon X4100, the other on top my B&K. I am thinking about one for my Xbox One to help as well
    These run super quiet and you can program them to be one speed, or increase as the temp rises.
    All with a couple button clicks.
  • steveinaz
    steveinaz Posts: 19,545
    Many component cooling fans now have adjustable voltages to minimize fan noise. I ran mine at 6.5volts and could not hear it, even when right on top of it; and it kept my HCA-1500 bacon fryer cool.
    edited May 2018
    @steveinaz I liked the way yours looked too, and it can hold more weight than these. I think your not supposed to put something more than 30lbs on it, which in my case means my AVR barely would work on top it (if it would actually fit in the unit like that).
    In this case, the little button with a fan logo on it (right side) actually indicates if the fans are running, and if so at what speed. You can set it to just let them run 24/7 at a given speed, or let it go to automatic where it will ramp up as the temp ramps up (which is what I have it set to).
    At top speed they are VERY LOUD. Mine tend to stay at whisper quiet though if I'm getting ready to run my Audyseey XT32 calibration (during which I kill breakers to the fridge, AC, fans, etc) then I can hear it, but thats a very rare thing.
  • steveinaz
    Wish I could remember the brand....hmmm...yes the build quality was nice, and the paint finish looked just like my amplifier texture/color. I sat mine on top to draw hot air up and out (through the internal heat sinks).
    steveinaz wrote: »
    Cool components :smile:
    Here is your review thread on it (read it a few times perhaps :wink:)
  • mpitogo
    mpitogo Posts: 516
    edited May 2018
    The fan looks to have been designed for Marantz. I suggest active cooling to help with longevity. Mine used to get very hot, I bought one and I’ve set the fan auto temp to turn on and adjust speed based on heat output of the receiver. The fan always turns on after a few minutes but never gets out of the lowest speed. It’s also a great match style wise.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • zeppage2
    zeppage2 Posts: 196
    edited May 2018
    Thanks to this thread, I picked one up (AIRCOM T8) through Amazon.
    I am interested to see if it will survive atop a Rogue Atlas Magnum ll with a tube cage/cover.
    Even if it does it will still likely run very high and possibly loud, but it can’t hurt to try...
  • mrloren
    mrloren Posts: 2,474
    I have one of the Aircom on top of my bedroom SR5010. The TV stand it's in doesn't have very good ventilation so I added one. Before I added i after 30 minutes of light use it was hot enough to cook an egg, now nice and cool.
    I set the fan to auto, I can't hear it till it's over 3/4 and then it's not very noticeable
  • jimbo1421
    jimbo1421 Posts: 772
    I just set up a pair of AC Infinity Aircom S8's. I find that the half speed setting is just audible at 8' during quiet passages. I am still tinkering to see if it needs to go to 3/4 speed to stay below 88 degrees.
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
    gudnoyez Posts: 8,161
    I paid $30 for 2 little usb powered fans that pulls the heat up and pushes the heat out. I can watch movies at reference levels for hours and the old Onkyo AVR stays cool as a cucumber.
    gudnoyez wrote: »
    I started with doing that, but these coolers work better and are nicer because they are fully automatic.
    Double the price of what you paid, but IMHO worth it. I'm even tempted to get one for my XBox One
    edited June 2018
    No doubt the one you got is a good one,, the next one I get will be one of those. I have a Denon that I could move my old ones to, the Denon not used that much, but can get pretty warm when it's been running a while.
