B&K EX4420 specs
So I'm searching for a high current amp to take the place of my HCA1000. Read some good reviews on this amp and looked at the specs page of the owners manual. Shows 75amps peak to peak. Not entirely sure what peak to peak means but the HCA1000 is rated at 35 amps peak...are these an apples to apples comparison?
Yep, my name really is Bob.
  • vcwatkins
    vcwatkins Posts: 1,992
  • muncybob
    muncybob Posts: 3,262
    So, it appears to have good headroom and plenty of current. Did not realize that they were that old though. Still would like to know if amps rating peak to peak is any different than what Parasound's terminology is? Slightly different wording for the same measurement?
  • motorhead43026
    motorhead43026 Posts: 4,029
    edited May 2018
    The Parasound amperage is P-P. I think you have it incorrect on the HCA-1000, I have it @ 45 amps per channel.
    I know my A23 which is the Halo version of the HCA-1000 is 45 amps P-P.
    – Kevin Alfred Strom
  • Easy Runnin
    Easy Runnin Posts: 501
    edited May 2018
    I currently have both of those amps and a NAD 2400. In my opinion, the NAD would be a good upgrade and the B&K would be even a better upgrade.
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
