Is this guy using those little industrial blue square vibration pads?
He must have a plug for plack paint. :#
https://youtu.be/q92hgIn4l2s
    mhardy6647 Posts: 35,145
    I dunno; looks like mebbie?
    I do know that "this guy" does.
    I.e., don't underestimate them. ;)
  • motorhead43026
    motorhead43026 Posts: 4,017
    I use these blue things, best bang for the buck. Although I did blacken them with black magic marker.
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited May 2018
    I used to use hockey pucks...
    solid and dense and they won't F up your wood finish.... they do hurt tho...
    https://www.amazon.com/Faswin-Classic-Ice-Hockey-Puck/dp/B01FQ6H3V6/ref=sr_1_3?ie=UTF8&qid=1525971061&sr=8-3&keywords=hockey+pucks
    If I had some pucks laying around I would send them to you Bruce but I don't have any anymore so I can't give a puck...
    Garage | Polk Monitor 5B's
    I am heavily hockey pucked.
    The late Don "Mr. Warmth" Rickles would be proud.
  • Mikey081057
    I like Wolfgang's Puck's
    Viking64 Posts: 7,587
    I don't use pucks, but I have used Snug, Snout, Bottom, Lysander, Helena, Oberon, Miranda and Titania. Neptune, Titan, stars can frighten....
