Blade / Blade IC Cable
I just acquired a pair of SDA 2A's but of course no IC cable. I don't understand why all these people selling SDA speakers don't have these cables. Anyway, I'm planning on upgrading them in the future along with new Neutrik connectors but have to get my M7's back together first and rebuild my speaker budget. Can't wait to hear these but need to see about a male/male IC cable in the interim. Are these cables still available aftermarket or do they have to be fabricated. I found some older threads that said they were still made but not where to get them. Thanks
Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
    Tony M Posts: 11,728
    It's just too soon for me to know if I have an extra one. It might take a week. :(
    I just won Dave's Karma of one B/B cable. :) I haven't got to cleaning up enough to swap out my older one for his new one. I have a couple of other SDA's in the back room and I forget if I have cables for each set. I think I do. ;) I'll try to get on it soon!
  • ThomasD
    ThomasD Posts: 260
    That would be awesome. You can PM me for pricing and shipping if ones available. Please keep me in mind. Thanks
    pitdogg2 Posts: 27,313
    Polk still makes and sells the blade/blade cables
    Smallies what is all the nonsense you are dropping in these threads? How does this relate to this thread?
  • ThomasD
    ThomasD Posts: 260
    Still available from Polk? Are they NOS or do they still manufacture them? Hopefully @Tony M will have one available that I can recycle. If not I now know I can order them, Thanks @pittdogg2. Will be upgrading the 2A's but would sure like to be listening to them while working on my 7's. B)
    They make them, about 50$ last i knew
  • verb
    verb Posts: 10,176
  • ThomasD
    ThomasD Posts: 260
    Was that @Tony M that scored that? Guess I didn’t realize the blade/blade IC cables were so available. Was considering cobbling a cable together just to get them up and running but it may be awhile before they get upgraded so thought I’d hold out for a proper cable.
    :p Yes, it was. :)B)
    Go ahead and get that one from Ebay. you can't go wrong. Fast and Free shipping. Boom, Done. 2 days to your door maybe!
  • ThomasD
    ThomasD Posts: 260
    @Tony M Thanks, no problem. Don't know exactly my layout yet, will the 16ga. be a problem if I get the 20' cable? Seems a little small but I'm not going to be pushing the 2A's with much power to start with.
  • ThomasD
    ThomasD Posts: 260
    You know, I'm really being pretty stupid or just getting too old to think clearly. I'm a frickin' electrical contractor. I have put literally thousands of cord ends on cables. I have thousands of feet of CL2 24-10ga. cable in my shop. Duhhhhhh. So where can I just order the 2- Blade plugs from?
  • dkfreebird
    dkfreebird Posts: 1,186
    edited April 2018
    eBay. Cinch Jones plug. That is where I got mine. I will see if I can find the number on eBay. Pretty sure it is the p-302 part number.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • ThomasD
    ThomasD Posts: 260
    Cinch Jones plug
    Didn't know that was what it was called. Would have never found it.
  • dkfreebird
    Looks like the price has tripled since I bought mine. They were only 3 dollars then.
    Oppo 103
    Pangea PC
    F1nut Posts: 52,000
    ^ Otherwise known as doing it half-a$$ed ^
