Getting back on the horse
heiney9
So I admit, I took a bit of a break from audio over the Fall/Winter. Normally Winter and the heat of my amp go hand in hand. I stopped (cold turkey) buying tubes about a year ago. It had become quite an obsession and I just couldn't pass up a deal.....lol. Sort of audio crack. The thrill of the hunt, the thrill of the deal, etc was addicting. Plus I have accumulated just about everything under the sun with respect to 6SL7; ECC81: ECC82; ECC83; 6x4; 6V6; 6L6 and variants.
I bought a new GTi in May of last year and that really put the kibosh on tube buying (didn't need to buy tubes anyway since I had everything). The down payment wiped out my audio fund (or seriously made a dent in it). That was fine as the timing was right and the deal was very good.
Last weekend I fired up the rig for probably the 3rd or 4th time in a year. Wow, was that sweet music to my ears. Made me fall back into love again with audio again. Probably the wrong time of the season since I'm a lot busier this time of year.
The audio funds are built back up again and I found a new piece of gear which will probably be my final stopping point, for a long time, maybe forever. It was just released so I want to wait until it trickles into the used market.
But I'm glad to be back on the horse and frankly, I needed the break. I was starting to drive myself crazy over analyzing each listening session. Sometimes you need to step away and come back to enjoy it again.
I'll have to finish this post later.......................more to come on the new piece of gear.
P.s. I never even finished putting together my Dreadnaught! Shame on me. All the parts are sitting in a box. That's project numero uno!
Back from hibernation! Spring is here!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Alright!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Congrats on the GTI man! Summer is here, that’s when guns, camping, and car hobbies take over. It’s been a long winter, I don’t see the stereo getting much use this summer.
I’m taking a step back as well, Buy some music and just enjoy the music. The constant analyzing of the system can get exhausting. I’ve calmed right down on the tube hunt. I’ve actually found a combo that really works.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
This is what's on the horizon for me. Started shipping in the past couple of weeks.
https://www.dagogo.com/pass-labs-shipping-new-xa25-class-power-amplifier/"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Oooh, yummy, Like the new face and heat sink designs.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
It has an entirely new power FET's for the output. Only 2 devices needed per side. Another "flavor" from Nelson Pass. Since this stuff depreciates so fast right away I'd like to wait and find a demo or used unit.
But I've been doing some preliminary reading and while this is the "baby" in the line up, it's no slouch and the FET outputs might trickle up. Love all the simplicity and care taken to transfer the signal as undiluted as possible, even more so than in the past. And at 55lbs the chassis is lighter and smaller. Now I don't have to worry about it breaking my stand, etc. Lol
Simpler and fewer gain stages improves speed and stability. Lower voltages mean the ability to run gain devices at higher bias currents, more deeply into Class A.
Newer power FET technology replaces banks of parallel small transistors with a single pair of industrial devices, each having a 700 watt / 40 amp rating. With no current-hogging issues and a new constant-current bias circuit to compensate for temperature drift, they connect directly to the loudspeaker without ballast resistors for lowest possible distortion and highest damping factor. No degeneration also increases the efficiency and Class A operating current, allowing greater Class A operation into low impedance and reactive loads.
The simple front end circuit uses two pairs of NOS complementary FETs in common-source mode in a current feedback (CFA) configuration. The amplifier is direct coupled and has no DC servos or frequency compensation.
I just hope I can wait.
Dang..when I saw the title of your thread and before I read it I thought you were going to have a Needle And The Damage Done moment...Glad it is about getting back into audio...LMFAO!!..
Nelson Pass couldn't design a single pole light switch to save his life.
Russ, bugger off! You're just jealous he won't let you run your fingers through his beard!
Guts shot is always a must.
25 watts of Class A sexy.... -
They had a very nice room at Axpona. Loved seeing the amps broken down into sections.
IMPRESSIVE!
Welcome back Brock -
The main thing holding me back in the past was I didn't have Dreadnaught. Now I do, well it's not 100% assembled yet. I'm ready to move on from the Aleph 30. I've had that amp almost 10 years. Of course I'll compare the two to make sure the XA25 is a good fit before selling the Aleph 30.
It's nice to be excited about audio again.
The only problem with Pass's stuff is that lack of tubes
In all seriousness, there's a hifi guy I know in MA who has an astonishing collection of equipment. He's not all tube though... he uses Pass amplifiers (don't ask me which ones) for bass and has nothing but good things to say about 'em.
The stuff is, sadly, too rich for my blood -- were it not, there'd be some Pass Labs or FirstWatt equipment here, without a doubt.
I misread the date this amp was released. April 2017 not 2018, dang I need to pay better attention. That's good news, that means they will be a bit easier to find slightly owned."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
slightly owned -- that's a new one on me!
I like it!
Somewhere between brand spankin' new and rode hard and put away wet.
mhardy6647 wrote: »slightly owned -- that's a new one on me!
I like it!
Signature stuff right there!
I see he has abandoned the need for the gobs of thermistors2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
gobs of thermsistors has a nice ring to it, too.
Great moniker for an alternative music collaborative, methinks.
Direct connection to speakers w/o ballast resistors also. Degeneration (another form of distortion) is eliminated.
According to Nelson Pass: “As with all Pass amplifiers, the technology and construction are strictly in the service of the listening experience. The XA25 measures superbly, but its subjective qualities are most special. In an industry where products with great specs are often found to be dry and boring, this amplifier breathes new life into the music. “It follows the philosophy of PL amplifier design – still greater performance with still simpler circuitry.”"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
mhardy6647 wrote: »In all seriousness, there's a hifi guy I know in MA who has an astonishing collection of equipment. He's not all tube though... he uses Pass amplifiers (don't ask me which ones) for bass and has nothing but good things to say about 'em.
Perhaps if you were to thin the herd a bit and offer up some of those dump-find gems of yours, you could raise the coin for some Pass Labs goodness. You could also make some points with your better half.
mhardy6647 wrote: »The only problem with Pass's stuff is that lack of tubes
I have that covered w/ a tubed dac and preamp that uses 9 tubes. Many say (especially of the First Watt stuff) because his designs are based on simplicity and fewer gain stages, they emulate many of the characteristics of tubes.
I'll sell you my Aleph 30, a superb amp especially for those that favor a tube sound."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
mmm... I shall cogitate & may get in touch 'off-line'.
Nothin's off line
mhardy6647 wrote: »mhardy6647 wrote: »The only problem with Pass's stuff is that lack of tubes
That's cool, but I have to find an XA25 to buy. It may be 6 months or so before I do this. But you seem like you're a patient guy
patient = lazy and unfocused (in my case).
You read me like a book!
I've been going back through some interviews and this question in Audiophile Review and the answer has always struck a chord with me. This interview is from 2011. Anyone who thinks measurements are the end all is just not all that well informed and extremely short sighted and.......well........wrong!, IMO
Audiophile Review: In 2011, have we reached a point where amplifiers won't be getting much better or does amplifier design have a long way to go towards perfection?
Nelson Pass: There is progress to be made, and the necessary tools are already on the table. From a strictly objective standpoint we are largely finished - adding more zeros to the usual distortion numbers isn't going to improve the sound very much.
What remains is the need for clearer insight into subjective effects. Our brains are very much different from test equipment and are easily fooled by some phenomena and very sharp at discriminating others. Reading the literature in cognitive psychology, it's clear that we don't know very much about musical perception.
As a practical result we have to emphasize critical listening with potential designs. The necessary tools for this are experienced ears and perseverance.
The XA25 is "a simple 3 stage circuit with total of three pair of push-pull gain transistors. In their ideal state, matched push-pull FETs give perfect 'square law' cancellation of distortion, an effect somewhat spoiled by degenerative Source resistance used to constrain the 'personality' of the devices. The removal of this form of feedback is an important element in the performance of the XA25 and is accomplished by new approaches to stabilizing gain and bias of push-pull FETs."
These statements here are what intrigues me about this new Pass amp."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
