Powering my new RTi A9's
Hi Guys,
This is my first post so be gentle with me!
I just swapped out my RTi A7's for A9's to complete my Polk 7.1 system: CSi A6 center, FXi A6 surrounds, FXi A4 rear surrounds, DSW Pro 660wi sub, Denon AVR-3313CI and a recently purchased Outlaw 5000 5 channel power amp.
When I first purchased the Outlaw(pre A9's) I hooked it up to my A7's and was pretty impressed by the difference in detail and power, particularly at low volumes.
Now that I have the A9's hooked up I am pretty disappointed and regretting the upgrade. I am thinking the Outlaw is underpowered (140 wpc) to drive the A9's sufficiently.
Was thinking about purchasing two Outlaw 2200 monoblock amps (200wpc) to power the A9's and use the 5000 to power my centre and surrounds(might be overkill).
Any thoughts on this approach or suggestions on alternatives. The Outlaw is only two weeks old so could be returned if there is a better option(not looking to buy used or break the bank).
I am Toronto based so any options would have to be from companies that sell in the city or ship to Canada,
Cheers!
Panasonic 60" plasma, Denon AVR-3313CI, Outlaw 5000, Polk Rti A9's, CSi A6, FXi A4's & A6's
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    Give those a9’s some time to break in and re evaluate in a couple weeks.
    Clipdat Posts: 13,095
    edited April 2018
    Shouldn't your current Outlaw amp be adequate?
  • chumlie
    chumlie Posts: 8,658
    What's this overkill you speak of. Sounds like a great plan.
    F1nut Posts: 51,760
    Why do people think bigger is always going to be better?
  • rpf65
    rpf65 Posts: 2,127
    i would probably look into something different than those outlaw mono's. They have some pretty good amp manufacturers up that way, shouldn't be hard to find a good high current amp.
    Toronto should have an dealer or two, and always keep an eye on Canuck audio mart. Amps last a long time.
    My wife always tells me "size doesn't matter", but I think she's just being nice.
  • cfrizz
    cfrizz Posts: 13,415
    If you are happy with the Outlaw 5000, then yes get a couple of 2200s. The 9s will operate much better with more power. All the other speakers will appreciate the power of the 5000.
    gudnoyez Posts: 8,161
    edited April 2018
    The 5000 is 120 wpc so, yeah get a couple 2200's for the A9's, thats about $1300 you will have in outlaw gear for your 7.1 rig if you go that route.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited April 2018
    Yeah, RTiA7s are excellent speakers!
  • jeremymarcinko
    The 9s are not just bigger. Their design is drastically different.
  • dolbyd
    dolbyd Posts: 430
    Agreed. With that sealed upper section and the extra bass driver they want power no doubt.
    The RTiA7 is great too and is easier on power requirements for sure. I just think for theater usage the 9's are hard to not get. Sadly people underestimate the power they require for performance and longevity.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva DR2 G3, Sony 85" Bravia 9, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA7 G3, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 80J 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
  • KPGM
    KPGM Posts: 8
    gudnoyez wrote: »
    Don’t really know amps so just not sure what else I could purchase new in that price range that would give me the power I need.
  • dolbyd
    dolbyd Posts: 430
    KPGM wrote: »
    gudnoyez wrote: »
    If it has to be new Matching your Outlaw 5000 with the 2200s is a good choice. 200 watts is a good # for the 9's.
    F1nut Posts: 51,760
    KPGM wrote: »
    Hi Guys,
    Cheers!
    Why did you think swapping the 7's for the 9's was a good idea since it appears you were happy with the 7's?
