Center Channel Speaker Choice
mgill
mgill Posts: 9
Question: 255c-LS or 265-LS for center channel in an 11.2 setup.
Building a new home theater setup and want everything in-wall. All six (lower) channels will be 265-LS, but the center channel wall location is in a wall bay shared by a pvc pipe coming down from the upstairs floor. The width of the 255c-LS I think is two inches too wide to allow to be mounted next to the pipe when oriented horizontally.
So I have two choices - install a 255c-LS turned at 90 degrees so the longer dimension is the height. Or, just get a 7th 265-LS and use one for the center channel. Looking at the specs its hard to see if that would be a problem. My power will be at 200 watts a channel.
Suggestions?
  • FestYboy
    FestYboy Posts: 3,861
    Go big and run it vertical, especially if it sits behind the screen.
  • mpitogo
    mpitogo Posts: 520
    Center is the most important speaker in an HT setup get the best you can and there shouldn’t be a problem mounting it vertically.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • mgill
    mgill Posts: 9
    Thanks all. Ill go with the 6 265s and the 1 255 for center channel - and mount it vertically.
