Panasonic RD-3100 turntable, any good?
KLapinas
in Electronics
Looking for opinions and value for this turntable?
Keith
Keith
If google images are to be believed
it's a rebadged BSR. On the bright side, it will take a 1/2 inch mount cartridge (i.e., you could put a heavish-tracking MM cartridge in it) and it appears to have a metal, rather than plastic, platter.
On the not-so-bright side, it is, to a first approximation, junk.
Not complete and utter junk -- but it's on the spectrum.
OK, Thanks.
Looks like one of those old Radio Shack LAB tables from the early 70's.....
Many of theirs were BSR OEM.
The better ones were Miracords (in those days), but they were labeled as such.
... and "better" is relative
all three of these, e.g., are BSR-made.
source: www.radioshackcatalogs.com (1977)
The Miracords (and some lesser BSRs) from 1977
mhardy6647 wrote: »If google images are to be believed
Way to let a guy down easy professor!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I think I was very balanced and fair.
It should work and, equipped with an appropriate cartridge at appropriate tracking force, and aligned with reasonable care -- it could provide satisfactory results... but the light platter and idler drive* (especially with four decade old idler rubber) won't give that inky black background and snappy PRaT much beloved by 'audiophiles'.
___________________
* Pretty sure that would be idler, and not belt drive. -
mhardy6647 wrote: »It should work and, equipped with an appropriate cartridge at appropriate tracking force, and aligned with reasonable care -- it could provide satisfactory results... but the light platter and idler drive* (especially with four decade old idler rubber) won't give that inky black background and snappy PRaT much beloved by 'audiophiles'.
Now that's the professor we all know and love!
Looks like the BSR stuff was trying to copy the Dual TT's back in the day! I know that Duals are some of the best made tables out there but I just can't seem to get over that they aesthetically look like plastic toys! I know the chassis on the Duals are black metal but they just all together, along with the tone arm look like plastic junk!
I wasn't trying to offend anyone who loves Duals, by the way ,just my humble opinion!
