Marantz AMP-1 in the house!
verb
verb Posts: 10,176
So I finally stepped into the digital rabbit hole!
Marantz AMP-1 integrated amp with their renowned DAC! Bad pic, but trying to hide the mess in the office!
Finally going to say goodbye to my Logitech 5.1 (using only 3.1) setup with the computer!
Oh yeah, generic audio output from the MB.
I have a pair of Acoustic Technolgies Classics that I'll use for my computer nearfield setup!
More to come! :smile:
  • verb
    verb Posts: 10,176
    DSkip wrote: »
    Nice! Keep us posted.
    Thank you Skip! I really appreciate your guidance!
  • mdaudioguy
    mdaudioguy Posts: 5,165
  • verb
    verb Posts: 10,176
    mdaudioguy wrote: »
    Cool - enjoy! :)
    Thanks dude! BTW the wood side panels look really cool! :smile:
    F1nut Posts: 51,719
    Love the looks. You need the matching CDP.
  • mdaudioguy
    verb wrote: »
    mdaudioguy wrote: »
    Cool - enjoy! :)
    See if you can pry them off with a screwdriver. >:)
  • verb
    verb Posts: 10,176
    So today I had the chance to hook up the AMP-1. Yay!
    Paired with a set of new Acoustic Technologies Classic speakers. MIT Terminator2 cables. Office nearfield setup using my PC as source. Using iTunes at the moment (yes I know) with their lossless format.
    So far so good! More impression to follow!
  • verb
    verb Posts: 10,176
    So today I started playing with the Marantz control panel in Windows7. This pops up. No info in the manual, none that I could find on-line. Anyone have any experience with it?
    Latency values range from 1 - 32 msec
    Buffer Size ranges from 64 - 32768 samples, or auto
    The settings shown in the pic were default when I installed the driver.
    Clipdat Posts: 13,089
    Looks like a fairly typical driver for a USB audio interface. I have a similar one for my Numark V7 which is essentially a DJ style DAC.
    I'd just leave them as is/default. Honestly you shouldn't even need the Marantz specific software installed. Unless perhaps for high res content playback?
    verb wrote: »
  • verb
    verb Posts: 10,176
    Cool thanks. I was playing with it a bit. It allows you to change the settings in real time, but no discernible difference to my ears.
    Yep, should not have an aural impact which is why I'd just recommend the default setting. All it's controlling is the size of the buffer, and how quickly the computer should be filling it up.
    verb wrote: »
  • verb
    verb Posts: 10,176
    Good to know. But since they put it there, I just had to play with it!
  • verb
    verb Posts: 10,176
    Here's another one. Default setting shown.
    Options are 24 or 32 bit.
    txcoastal1 Posts: 13,505
    verb wrote: »
    That's what I tell the ladies
    What is your primary source? I'm assuming it's 16 bit.
    16 bit can populate/be carried by a 24 bit container. Unless you're playing high res 32 bit content I'd just leave it at 24.
    verb wrote: »
  • FestYboy
    FestYboy Posts: 3,861
    Think about that one like the visual difference between the NES and the N64...
    But does the Marantz have "Blast Processing"!?
    http://www.nintendolife.com/news/2015/11/the_man_responsible_for_segas_blast_processing_gimmick_is_sorry_for_creating_that_ghastly_phrase
    FestYboy wrote: »
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    verb wrote: »
    Gotcha. The Queensrych SHM CD was remastered in 24bit.
