rdo-194
good morning,
I have searched all over google, and searched though the forum without any luck.
does anyone know if there is a list of models that the rdo-194 tweeter came in, or was it just an aftermarket replacement tweeter?
  • DaveHo
    DaveHo Posts: 3,580
    rdo-194 & rdo-198 were never stock tweeters. I'll defer to someone more knowledgeable than me to tell you which tweeters the 194 can be used in place of.
  • ok, that actually answers my question. there are a lot of used polks of all years available near me, and was trying to see if I could find a pair with the 194's in them for a project I have, but I will just order from polk.
    thanks for the quick response.
    pitdogg2 Posts: 26,927
    Anything that had a SL2000 tweeter has the ability to use the RD-0194
    Anything that had a SL2500/3000 has the ability to use the RD-0198
    now to cloud it up a bit the RD-0194 can be used on the speakers that had a SL1000 tweeter but some modification will need to be done to the cut out to accommodate the RD-194
    The RD-194/198 is not a replacement for any speaker that came with the Peerless tweeter.
  • I have some sda2b that I am upgrading, was just seeing if the 194 came stock in anything before I ordered from polk. there is an endless supply of used polks here
  • TNTsTunes
    TNTsTunes Posts: 751
    Many members will add a 5.8uf cap to the crossover and use RDO198's in the effectively creating SDA2B TL's.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • im not sure I want to get into a crossover upgrade quite yet.
  • dromunds
    dromunds Posts: 10,094
    Tell Polk you are a forum member and get a discount on your order
  • FestYboy
    FestYboy Posts: 3,861
    Where might "here" be?
  • dkfreebird
    dkfreebird Posts: 1,186
    FestYboy wrote: »
    You just stay up north and leave some vintage speakers for us southerners. :D
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
    audioluvr Posts: 5,874
    FestYboy wrote: »
    Where rainbows come shooting out your arshe
  • in texas, not all of them are vintage though. but there were 3 pairs of srs 3.1 for sale recently. I think one or more are still listed.
    if I didn't have to pay a couple grand for an immigration atty, I would be buying a set
    F1nut Posts: 51,674
    Yes, you do.
  • george daniel
    george daniel Posts: 12,096
    Yes, you do.
    What he said^^^^^^^^^^^
  • Anybody have an idea of a ballpark cost estimate for getting the crossovers done?
  • FestYboy
    That strongly depends on the components used...
  • That’s why I said ballpark.
    Not low end, not crazy high end
  • FestYboy
    30-50 per cap? If you're budget minded. Someone else should chime in with resistor numbers. Most don't touch the inductor as it doesn't degrade over time like the caps will.
    $500ish?
  • good lord. im definitely not doing those now.
    Clarity and imaging will have a huge improvement
  • im sure it would be, but besides the tweeters, there is no way I can justify spending $500 right now to upgrade speakers that already sound great. plus, ive got to drop about $10k on an immigration atty so its on the wayyyy back burner.
