Signature S 55 with CsiA6
dowop
dowop Posts: 30
I am currently running the CsiA6 with Rti A3`s.
Can pickup a pair of S55`s for a good price.
Would I notice a big difference? I do not want to replace the CsiA6 either.
Any comments would be appreciated.
  • cfrizz
    cfrizz Posts: 13,415
    Only your ears will tell you if you like the combined sound of the 55s and the CsiA6. Try it and see.
  • dowop
    dowop Posts: 30
    Good advice. Problem is I can not return the speakers if I dont like them.
  • cfrizz
    I'm pretty sure you will like the Signature 55s, they aren't as bright as the CsiAs and do well with both music and movies. Or you can look for a deal on the 55s elsewhere. It seems like someone is always running a special on them.
    F1nut Posts: 51,959
    They will not be timbre matched, so yeah you will notice.
  • dowop
    dowop Posts: 30
    The deal fell through.Thanks for the advice though.
  • mrloren
    mrloren Posts: 2,474
    edited March 2018
    Yes they are not timbre matched but it will blend very well.
    I have a CSi-A6 with my S60, it blends very nice. I've tried 3 different center speakers with my current setup. S30, TSX250c and CSi-A6. Out of the 3 I like the A6 the best. Dialog is very clear with a nice rich detail the other speakers missed, mostly the TSX250c.
