Difference between single and dual coil
hbrandi
Hi everybody!
What is the difference between a subwoofer of one coil or those with two coils? My brother is donating me an amplifier with five channels. In the car audio forum recommend me to buy a sub with two coils. If my amp has only one channel available a double coiled subwoofer could be used? If so how can I connect it? If I connect only one coil of a double coiled subwoofer, the sw could be damaged?
Best regards
Best regards
Post edited by hbrandi on
yes, you can have a dvc sub on a 1 channel amp
as far as wiring goes...it depends on the sub and the amp
DVC allows more ways to hook up your sub. Parallel, series, resistance loaded, dual coil or single coil. All offer their different results, but no SVC woofer by itself can offer this many options.
It simply makes it easier to find hookup options that will best match your amplifier when you have chosen a single driver as your sub.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
bit of translation for what dennis said - you can wire the coils in parallel or serial, or you can short one out with a resistor (good way to change the effective q of the driver, see this pdf from adire). you can also drive only one coil, or you can push both separately (despite what you may have heard, this won't hurt the sub).It's not good, very fundamentally simply not good. - geolemon
I know tweeter isn't the most reliable source of info but they told me it would be better If I bought the DVC instead of the SVC for the MM2124. They said the DVC would handle the power better. I have 2 MM2124 SVC and two JL 500/1. Is it true that DVC handles power better?
Yes. Take the MM2124. It handles 400 rms. Thats 400 watts per coil. The DVC MM2124 handles 400 per coil. And since the JL amps puts out 500 at 1-4 ohms it would split the power to 250 per coil so in this remote case, the Tweeter guy is actually right!polkaudio sound quality competitor since 2005
Good to know unfortunately I bought SVC and thats all CC covers. On my next setup I'll buy DVC. Thanks
That's all cc covers? please explain...Originally posted by max3
do you mean that's all we carry?
-adamcats.vans.bag... -
yes sorry circuit city only carries SVC. I think when tweeter picked them up they demanded it be DVC so they sell those now. Not sure if thats true though.
we have a few DVC subs at cc... but otherwise we carry very **** subwoofers....Originally posted by max3
u have DVC for MOMO?Originally posted by swerve
-adam -
CC doesn't even have MOMO anymore... that's why i said "****".Originally posted by max3
Love forever and always,
Yup, Circuit City is no longer a viable player in the car audio community as far as Im concerned. That pisses me off too cause Ive been buying gear from there for about 15 years!! From Alpine V12's to Verge. :mad:polkaudio sound quality competitor since 2005
