What $200 can build you
Mazeroth
Mazeroth Posts: 1,585
edited November 2004 in Speakers
I've been heavy into DiY speaker building for the last 6 months and can't believe what you can create for such little money. Check out what a guy I met two months ago at the Dayton, Ohio Parts Express speaker meet just built for $200.
http://www.pesupport.com/cgi-bin/config.pl?read=195545
I built a simple line array with the same 4" woofer Sid used in his computer speakers. 16 per side with 32 3/4" tweeters. They sound amazing for only $40 each with wood and crossover. If you guys want to take your audio careers :D to the next level, highly consider building some speakers. I find it undoubtebly more rewarding than just buying a pair, but others will think differently.
Enjoy!
Post edited by Mazeroth on
    VR3 Posts: 29,427
    I wanna see pictures of yours dude...
    32 tweeters? Holy god...
  • gatemplin
    gatemplin Posts: 1,595
    Hi Maz,
    I see you over at DIYaudio quite often. I have built several speakers before and am building a new pair sometime soon. I am using the Adire Audio Extremis 6 in a MT. I am trying to get Jon Marsh to do, or help me do a crossover with some LPG 26T tweeters. It is very satisfying to hear something you have built.
    Graham
