Infinite Baffle
124
    VR3 Posts: 29,425
    I actually like the sound better with a smaller cut out, little more upper frequency range but doesn't seem to sacrifice the lower end
  • monepolk
    monepolk Posts: 1,154
    Is this under your floor?
    VR3 Posts: 29,425
    Yes
  • monepolk
    Gotcha, interested in how you finish it off.
    VR3 Posts: 29,425
    edited March 2018
    I am having a stainless grate made. Will be 1/2 thick plate, 1/2" holes in a waffle pattern. Outer frame will be 1" wide with a1/4 flange for flooring to butt underneath
    I am definitely going to make the opening smaller, half the size of the picture
    Will mount the second pair of woofers in a few weeks
    VR3 Posts: 29,425
    Had an extra set of hands yesterday. I was going to mount the other two on the other side if the room but decided there just wasn't enough clearance in the drawl space...
    So we moved the previous two over and mounted the next two beside them. Used the same cut out as before and I see no disadvantage to this. For the money invested, the bass is incredible. Effortless, clean, zero distortion, tight, simply amazing. rbgzuatlct5w.jpg
    mhardy6647 Posts: 34,998
    VR3 wrote: »
    Wow -- that looks just like one of my attempts at crafting my own speaker cabinets :)
    VR3 Posts: 29,425
    edited April 2018
    Lol, I know right. I literally used scraps of wood and plywood I had laying around. I'm having a 1/2 thick plate of stainless steel to cover it will be nice and discrete
    EndersShadow Posts: 17,704
    Looks like a proper infinite baffle installation to me!
    Now just keep those cones dry and moisture free for years of infinite fun :wink:
    Now just keep those cones dry and moisture free for infinite years of infinite fun :wink:
    Fixed that for you.
    VR3 Posts: 29,425
    Do I need to do anything in the winter? Just curious...
    These subs literally fill my entire house with bass. I can feel low notes in my office area some 30-40 feet away. I love the face it takes up zero floor space... ZERO
    VR3 wrote: »
    Not sure TBH. I think there are some threads on that somewhere. search "cult of infinite baffle", that comes to mind for some reason...
    Glad your happy with it.
    Sidenote, on another site a bunch of guys are working with FI Audio to build some new versions of his existing subs meant more for HT than Car Audio.
    If I ever had the the option of building a IB setup, I'd be all over it, so consider me jealous :smile:
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    I just got back on the forum and looked up your progress Trey, glad to see that you went with 4 drivers and are getting the bass that you hoped for.
    VR3 Posts: 29,425
    Thanks Dennis, they are more than I expected. I am thinking I will use the other two in my office rig in the ceiling lol
    VR3 wrote: »
    Nah, just buy 4 more.....
    VR3 Posts: 29,425
    I honestly feel anything more than 4 would equate to structural damage
    VR3 wrote: »
    Unrelated, but AVSForum has a thread on some new HT based FI drivers meant for normal sealed use.
    VR3 Posts: 29,425
    edited July 2018
    3/8" stainless steel grate... Not going anywhere
    Will put a sheet of reticulated foam down and a foam surround to prevent hair and dirty going down in the cubby and make it easy to clean
    pitdogg2 Posts: 27,034
    That oughta do it
    What about grill cloth under it too?
    VR3 Posts: 29,425
    edited July 2018
    The reticulated foam looks like grill cloth
    VR3 Posts: 29,425
    I hated the look of the grills when I first set the Wilsons up but they grew on me really really quick. I really like how easy it is to stretch/remove/replace the foam in the event of age or wear.... it attaches like velcro
    Gotcha, never seen that stuff before. Wheres the installed pic Trey? Cmon.... being lazy I take it?
    VR3 Posts: 29,425
    Not quite ready to install it. Been slammed at work the past month so haven't had much time on my hands
  • Airplay355
    Airplay355 Posts: 4,298
    Next order of business will be to find and eliminate everything in the house that rattles :D
    VR3 Posts: 29,425
    The only thing that really made noise was the fact the blinds over it were physically moving and hitting the window lol
    VR3 Posts: 29,425
    edited November 2018
    So just for giggles I was playing a 5hz test tone...
    Couldn't really feel or hear anything but at a certain volume the door to the office (about 30 ft away) would move back and forth in the jamb erratically... Was neat
  • verb
    verb Posts: 10,176
    VR3 wrote: »
    Interesting, and cool. What were you using to generate the test tone?
    VR3 Posts: 29,425
    Tidal had misc test tones 5, 10, 20, 30
    10hz was a little more interesting
