2.3 for center channell bi amped on 5x425?
13»
  • SDA1C
    SDA1C Posts: 2,072
    txcoastal1 wrote: »
    SDA1C wrote: »
    lightman1 wrote: »
    I'll rescue your 11t. Say the word.
    Not supposed to post without a price....
    Who said anything about money, rescue is a heroic gesture
    Pffft. Me.
    Too much **** to list....
  • SDA1C
    SDA1C Posts: 2,072
    Better yet. You drive from tx to spokane....ill give them to you.
  • FestYboy
    FestYboy Posts: 3,861
    SDA1C wrote: »
    Fb subs alone are 132 db. 11t dont stand a chance. Lol
    Just because they can reach that level doesn't mean they have to play at that level... The 11s can easily hit 100+dB, and in the room size you have, that should be more than adequate. Pressurizing that room to 130+dB will break things, including your ears.
    audioluvr Posts: 5,915
    If you could some how drive the SDA's out of phase, that would give you the time delay and hall effect... Or would make it sound like total ship. You be the judge.
    SDA1C wrote: »
    Wait you are in Spokane??? If your giving anything away, I'll drive there. You're only about 2 1/2 hours from me
  • SDA1C
    SDA1C Posts: 2,072
    Ill give them to txcoastal only. Good try though...
  • FestYboy
    txcoastal1 Posts: 13,512
    SDA1C wrote: »
    I live in Oregon
  • SDA1C
    SDA1C Posts: 2,072
    txcoastal1 wrote: »
    SDA1C wrote: »
    I live in Oregon
    Bummer lol
    txcoastal1 wrote: »
    I live in Oregon
    Sounds like you should expect some company... :D
  • kcoc321
    kcoc321 Posts: 1,788
    Here's a b stock k153 that would be timber matched to your k12. Sell8ng the 2.3 and 11t should get you close to the $$.
    http://www.proaudiostar.com/qsc-kw153.html
    Viking64 Posts: 7,547
    kcoc321 wrote: »
    timber matched
    Is that when the wood is the same?
  • FestYboy
    edited March 2018
  • SDA1C
    SDA1C Posts: 2,072
    kcoc321 wrote: »
    Considered 2 k8 for the center. The k15 pair is in next years budget as well as the touch mix but cabinets are too big for center duty.
  • SDA1C
    SDA1C Posts: 2,072
    audioluvr wrote: »
    txcoastal1 wrote: »
    I live in Oregon
    Hell of a trip to texas first but if you do drive from texas to spokane theyre yours.
    nooshinjohn Posts: 25,916
    SDA1C wrote: »
    audioluvr wrote: »
    txcoastal1 wrote: »
    I live in Oregon
    Sounds like a great idea Ron... I hear the Griswolds are planning another road trip and have room for one more person.
    SDA1C wrote: »
    audioluvr wrote: »
    txcoastal1 wrote: »
    I live in Oregon
    I'm looking on autotrader right now :)
  • SDA1C
    SDA1C Posts: 2,072
    For what. A "new to you" 2014 Chevy Silverado? Low miles?
    Is this an eww scarry topic or what? 2.3 in place up stairs already bi amped. Movin 400lb of gear up stairs and a raft of **** from the wife for a 3day audition?
    Nobody tried this????? Ever? 14k watts 8 ohm in one room? Effn SRT cant even do that!
  • gp4jesus
    gp4jesus Posts: 2,019
    I haven’t figured out the “bi-amp*” part - that’s* what caught my attention. Read my sig for why
    *all connected w/Premiere ICs
  • warren
    warren Posts: 756
    Your ears cannot distinguish the miniscule delay that occurs between the left signal and the right SDA signs (at the speed of light (186k mps), 15ft is nothing.
    The speed of light, hmmmmm..
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
    Generously rounded to 1:10,000th of a second...
  • Schurkey
    Schurkey Posts: 2,122
    The bass works just fine without the SDA interconnect cable. That's the point of the SDA inductors which are sometimes changed to a lower-DCR inductor to improve bass response.
    If you drive a pair of SDA speakers with a mono signal, there is no SDA effect*. You can leave the cable connected, or remove it. If it's removed, there's no issue with common-grounding, although with a mono signal there shouldn't be a problem with grounding even with the cable connected. For all I know, the QVC amps are appropriately common-ground anyway.
    *But of course someone is going to start up the "SDA is not an "effect"" argument.
  • FestYboy
    warren wrote: »
    This referring to the electrical signal within the circuit... All electrical signals run at SoL
  • SDA1C
    SDA1C Posts: 2,072
    gp4jesus wrote: »
    The bi amped part is as they are connected now. just jump the signal for the center out on the oppo to 4 of 5 channels in the sig425. curious about feed back splitting a mono 4 times. If no one has tried it i guess Ill have to sneak up on the idea and find out if there are adverse effects on my own.
  • SDA1C
    SDA1C Posts: 2,072
    warren wrote: »
    Im sure weve covered this but to refresh...the time delay is not noticed in the crossover board signal it is in the speed of sound as it travels from the drivers to your ears. and yes, there is a noticeable difference if standing from one side to another even with a mono signal.
  • gp4jesus
    SDA1C wrote: »
    gp4jesus wrote: »
    im still missin’ It
