Crossover Board Location
I recently picked up a pair of early DCM Time Windows. I am currently in the process of rebuilding/restoring them. I made new crossover boards and installed new caps, resistors and internal wiring. The c/o was originally mounted on the top inside the cabinet facing down. I changed the orientation of the air core inductors so instead of laying flat they are standing on end. See pictures. If I mount the c/o in the same place the inductors will be very close to the magnets of the 6" drivers. In my research, some people say that this can be a problem while other say it is not a problem. My other option is to perhaps mount them on the side of the cabinet below the tweeters. What do you all think??77agl4j7dr4g.jpg
    F1nut Posts: 51,732
    Move the crossover away from the driver magnet.
  • Faustin
    Faustin Posts: 1,151
    "Move the crossover away from the driver magnet."
    What would be a minimum distance?
    F1nut Posts: 51,732
    As far away as possible.
  • FestYboy
    FestYboy Posts: 3,861
    Think of it this way: why did Polk mount the XO right at on terminal cup? It was 2 fold, packaging, and it placed the XO far away from any magnetic field (usually). Obviously cabinet size incurrs it's own limitations.
  • Faustin
    Thanks for the input. I have decided to mount them on the side of the cabinet below the tweeters.
