Lightning ds freezes
afterburnt
Pretty much happens 50% of the time when I turn off the Satan ipad 2 mini. Does anyone else have this problem?
You seem to have a truly passionate hate for Apple products, why not just move on to another tablet? I don't get it...
I hope it's a fluke, I just bought an Auralic and am getting it set up now, having to futz with a broken app doesn't sound like something I'd stick with -
Furthermore this glitch is kindda new, started with one of the last updates of ios or lightning
Seriously, their software only runs on iOS?
AsSiMiLaTeD wrote: »Seriously, their software only runs on iOS?
Yep, thus my Faustian bargain -
Oh you can run the Auralic with something else but lightning only runs on ios
I was using an Auralic mini with an IPad Air and it was flawless. Since switching to the Aries Femto, with the same IPad, the app crashes at least 50% of the time. It seems to have nothing to do with the iPad, it is only the app that freezes then crashes.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Apple is still digital evil
I tend to have a long listening session on Friday, iPad is set to only go to sleep with the cover closed. The app will freeze in mid operation.
2 channel:
Theater:
I think I have auto update on so I'm not sure if its lightning or the prince of darkness
Sell me your Auralic Aries Mini for super cheap and your problem will be solved. In fact, you should pay me to take it off your hands.afterburnt wrote: »AsSiMiLaTeD wrote: »Seriously, their software only runs on iOS?
Still don't understand why you continue to use a product you hate so much, Samsung makes a great tablet as well try them out.afterburnt wrote: »Apple is still digital evil
OK I have a question for those using the app. This is gonna seem stupid but it's also gonna be a deal breaker for me if I cannot figure it out.
I want to browse my music by Genre > Artist > Album. So when I hit the genre filter and select a genre I'm expecting to see a list of all the artists, then I hit an artist and get their albums. This is the way JRiver and every other piece of intelligently designed library interface I've ever seen works.
Instead, by default, it does the same thing the idiotic default Apple Music app does...which makes literally zero sense to me. I select a genre and it shows me a list of albums in that genre, in order by album name. That seems completely nonsensical and is totally backwards from how I listen to music. I want to hit the Prog Rock genre, scroll to Steven Wilson, then see his albums instead of of having his albums thrown in a list of everyone else's...I really do not understand this design choice.
Can I make the Aries work the way I want?Post edited by AsSiMiLaTeD on -
my is only a problem as skip mentioned. changing programs or going to sleep. Overall super happy with the aries
Appreciate it, I’ll see if I can figure out the JRiver setup...I should also try Roon again
uh because it controls my Aries -
never -
See Skip's comment above, you can also use JRiver or Roon
AsSiMiLaTeD wrote: »See Skip's comment above, you can also use JRiver or RoonAsSiMiLaTeD wrote: »See Skip's comment above, you can also use JRiver or Roon
I already told you that you can run it with other stuff -
I won't diss Apple products have a few IPods and a IPad, but I like to keep it Simple. I use a couple of Chromecast audio's going through the Oppo's Dac, the Marantz's Dac or the Musical Fidelety M1 with a couple of Samsung tablets, and Galaxy phones. It's easy and hassle free and sounds good to boot. It's less time messing around and more time for the Tunes.Home Theater
has anyone here gotten the Aries to work with JRiver, and if so can you share the steps? I've set the Aries to a UPnP Rendered, which means it should show up in JRiver, but does not, I've been at this all afternoon and cannot figure it out...any help is appreciated
Voltz is probably running his with J River.
Maybe Father Merrin can help you?
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
No need for an exorcist it's just s nusome. I was just asking. I am actually glad to have such first world problems.
The title of this thread made me think of this. Since I now can't get it out of my head, neither will you be able to, either.
https://youtu.be/xsJ4O-nSveg -
So if you had the ROON app I think you would be able to control the Auralic with a non-Ios device.
You can try it for free.My New Year's resolution is 3840 × 2160
That Roon looks cool but I have a learning disability. I don't think I could learn how to use it in fourteen days. Anyway that Lightning glitch is just a newsome it doesn't really bother me. If someone has a fix great if no one has a fix great.
