Cambridge Audio DVD 99 Remote
audioluvr
Picked one of these up with no remote. Anyone know where I can get one?
There's several similar models of remote available on eBay. They might work cross models.
Go Harmony, don't look back.
Ah. Thanks Dave! I currently have 4 remotes in my TV room. I've been told I can program one remote for everything but have no clue what that entails. Maybe my teenage daughter can do it for me...Gustard X26 Pro DAC
I love my Harmony remotes & the interface for "programming" them. Very simple to configure, no real programming involved. They have a very large database of supported models. You can check if your particular ones are supported here:
https://support.myharmony.com/en-us/compatibility
You do not need the original remote to set-up the Harmony. -
Thanks, got one on order.Gustard X26 Pro DAC
