Sda srs interconnect cable upgrade?
  • sansuibutch
    sansuibutch Posts: 200
    I like the solder version best.
    Use one positive and one negative, then the same at the other end.
    Thank you. I installed the sockets, cut all the wires back and replace the eylets , snugged everything up nice and hot glued around the back of the sockets and the connections to the binding posts like the factory did. With the original ic and connectors in hand I can see that in fact the original did fit nice and snug wich I'm sure made for a good connection (never had any issues with connections) , but I measured the original ic and realized it was 50 foot long. 16/2 is stamped on the wire so I'm sure it's original. Hopefully tomarow il grab some wire to make the new one. I was kind of doubtful of any real gain to the new setup until I realized the original was so long. I'm going to make the new one right around half that length figuring that's around how far I can place them apart. Is 10 guage overkill for this interconnect?
    F1nut Posts: 51,786
    I recommend using the same type of cable you are using for your speaker cable. For me that meant using MIT Shotgun cable, no network boxes or CVT coupler.
    pitdogg2 Posts: 27,058
    10ga is not overkill in my book.
    What are your speaker cables? Many try and use the same for both.
  • sansuibutch
    I figured using the same as my speaker wire would be a good idea since it feeds the speakers to begin with but my speaker wire is more flat than round. I'm not so sure it would fit in the connectors well. I can't remember who makes it off hand but it's a very high strand bright copper 10guage. Any thoughts?
    Give it a go. Where there is a will there's a way.
  • sansuibutch
    After looking through my wires I have decided I'm not going to try to stuff any of my 2 wire cables in these neutrik connectors. I'm sure they will crush down when I tighten an up but I wont feel right about it. I noticed a lot of people used Canare 4s11 wire to make these interconnects. I figured doubled up they would be 11 guage and the cable would be round. I figured if this wire is as decent as everyone says it is Il buy enough to power the speakers also. Is this wire decent overall? And thank you for the help, it is much appreciated.
  • Canare is good quality, I don't think you will be disappointed.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • bikerd
    bikerd Posts: 3
    My sda1c have both pin and blade wires connected inside.
    Correct but only the pin carries the signal in a pin blade speaker.
  • Schurkey
    Schurkey Posts: 2,122
    The blade on the pin/blade socket, is there, and connected to the negative terminal, to make the system compatible with the AI-1 isolation transformer; a low-cost "plug in" solution for non-common-ground amplifiers.
    No AI-1 isolation transformer, no need for the blade connection.
    Aftermarket isolation transformer (Dreadnought or similar) can connect the transformer - cables directly to the - binding post on the speaker cabinets, or indirectly through aftermarket connections such as the popular Speakon stuff as illustrated previously.
    F1nut Posts: 51,786
    The blade connection is only used with the AI-1/Dreadnought. If you use both wires for your new SDA cable very bad things will happen.
