Joule pre overhaul...
kharp1kharp1 Posts: 3,342
I packed up the Joule and shipped it to Rich Brkich at Signature Sound today with the original intentions of having it looked at and basically doing a checkup on it. Started thinking that was kind of silly considering it is getting close to 20 years old now. So my plans were to spend $2k-$3k in replacing the caps (there's a bunch of them) and and upgrading them to some TOTL caps.
Now I'm wondering if maybe I'd be better off selling it as is (it still sounds great and performs flawlessly) and taking that money plus the 2-3k I was going to spend and maybe buying a new, different pre. I have no idea what that would be, I haven't really been looking around, I wasn't in the market for one.
Or, would the 2-3k investment in upgrading the Joule be the better return on sound investment. And, if so, what caps should I be looking at? I was initially thinking the Mundorf Supreme Evo Silver Gold Oil caps in the power supply section, but, Mr Brkich didn't particularly like the Supreme caps for the power section, instead recommended the Mundorf MTube caps (not familiar with them).
The Duelund's are a little trickier in that some of their caps have odd physical sizes, and, are expensive. Plus, he recommends the cast copper instead of the cast copper silver, stating that the silver takes it too far away from the "sound" of a Joule. If Duelunds are not an option, what other caps would be recommended? And what about that cap makes it a good choice? Anyone? Anyone? Bueller?
Main System:
Joule-Electra LA 100 MKIII Upgraded by Rich Brkich Pre
Butler Audio TBD 2250 Amp
PS Audio DirectStream DAC and MemoryPlayer Transport
LSA-1 Statement
SVS SB4000 & SB2000
Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
Secondary Rig:
Parasound P5, Audio Electronics by Cary Constellation
Marsh a200s, Audio Elecrtonics by Cary Hercules
Pioneer Elite DV-45a, Denon DVD-2910
Klipsch Epic CF-1, Vandersteen 3CE sig
Analysus Plus Oval
Backup Gear:
Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
Marantz SA-14S1
Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
«1345
  • nooshinjohnnooshinjohn Posts: 21,300
    Trade up and go for a Pass Labs XP20
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with Pass Labs Xono Phono Preamp, Walker Precision Motor Drive, ClearAudio Goldfinger Diamond v2 cartridge and Origin Conquerer Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X0.2 three chassis preamp, PS Audio PerfectWave DAC MkII, Pioneer Elite SC-LX701, Oppo UDP-205 4K Blu-ray player, Sony XBR70x850B 4k, Polk audio AB700/800 "in-wall" surrounds.
    Saying that it's "too hard" to pursue your dreams is no different than admitting to yourself that you are too lazy to achieve them.
    “If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
  • kharp1kharp1 Posts: 3,342
    And that's very much a possibility. The Joule doesn't offered balanced inputs/outputs, which isn't a big deal currently, but, would like to have any end game piece be truly balanced.
    Main System:
    LSA-1 Statement
    SVS SB4000 & SB2000
    Secondary Rig:
    Analysus Plus Oval
    Backup Gear:
    Marantz SA-14S1
  • headrottheadrott Posts: 5,432
    kharp1 wrote: »
    After going with Balanced Audio Technology, I haven't looked back. A balanced system, is exactly that.
    I think you have a great idea going fully balanced, IMO.
  • tonybtonyb Posts: 31,430
    kharp1 wrote: »
    Tough call Kerry. To me...an end game piece is about the sound, not the connections. I might look at other brands with similar characteristics if the Joule pleases you. VAC or VTL would be 2 places I'd look. The Cary 05 is nice too but re-tubing that sucker with good NOS tubes can get expensive. Cayin may be worth a look see also, though I've only heard one specific model of theirs but I did like what I heard.
    You can also spend 4-5k on a newer pre, and not like it as much as the Joule too. Spending more doesn't guarantee better sound.
    I might be more inclined to dig deeper with the guys at Signature sound. Get more of an insight as to what to expect, sound wise, after the upgrades. Maybe they can suggest an upgrade path for you that still mirrors your taste in sound also.
    If you stay on the Joule path, I've heard the Joule 300 is an end game piece, though finding one is like looking for a razor is Russ's boom truck.
    B&k 1430
    Tad 803 speakers
  • WagnerRCWagnerRC Posts: 1,939
    I believe you made a wise choice.
    tonyb wrote: »
    Admittedly. Russ doesn’t shave too often, but he does tend to cut himself all the time. Last I heard, his truck has so many wasted blades in it he can’t see out the windshield, except through a cardboard tube he uses like a periscope.
    Silly John, you know Russ has no razors....he has the Vet groom him every so often. :)
    My comments on the pre stands.....don't be in such a hurry to send it off, do a little digging to better define the path that best suits you.
    B&k 1430
    Tad 803 speakers
  • maxwardmaxward Posts: 377
    Thanks for posting this, @kharp1. That’s a tough decision you have, especially since the Joule is now in transit. The guy who sold mine to me had the LA-300ME in his main system, and it did sound wonderful. However, as Tony said, these are not often on the market and, who knows, the mods you are contemplating might get you most of the way there. I think Rich at Signature Sound will give you some good advice on that question. On the other hand, after watching Paul McGowan’s video on short vs long interconnects/speaker cables, it would be tempting to consider upgrading to a balanced preamp. Good luck.
    Thorens TD-160C; Sumiko Talisman S; Jolida JD9; Marantz CD-53; North Star Intenso;
    Joule-Electra LA-100; Balanced Power Technology AC conditioner;
    Odyssey Khartago monos (with most factory upgrades); Magnepan MG 3.6R
    I felt like it needed to go back just to get a once over and thorough checkup. I had been thinking about sending it in for a look see every since I picked it up over a year ago and things worked out where I had a good time period to send it in and give Rich time with it. He's pretty excited to use this as an opportunity to test and possibly offer an upgrade package for the future as these pieces are starting to get nearer the window of cap life.
    @tonyb the connections are not the main priority, however, all things being equal, I would like to have balanced capabilities though I realize just having the "connections" doesn't mean true balanced topography. The Joule will never achieve that by design, but, that doesn't mean it's not a really good piece now, and, can probably achieve an even greater level with newer, better caps and resistors, an, maybe some better internal wiring.
    RIch has stated he wants to get it in and give it a going over and run some tests before we start talking about what can go where and what it will do. If we can reach a quality to price point that I can live with I'm going to have the work done and see what kind of improvement it made.
    Main System:
    LSA-1 Statement
    SVS SB4000 & SB2000
    Secondary Rig:
    Analysus Plus Oval
    Backup Gear:
    Marantz SA-14S1
    Thank you. Keep us informed about what you and Rich decide to do. It will be interesting to hear about the results.
    maxward wrote: »
    Ditto.....
    B&k 1430
    Tad 803 speakers
    This one is on Rich's bench. not mine
    Geez, those are some monster caps back there!
    Main System:
    LSA-1 Statement
    SVS SB4000 & SB2000
    Secondary Rig:
    Analysus Plus Oval
    Backup Gear:
    Marantz SA-14S1
  • DSkipDSkip Posts: 16,110
    kharp1 wrote: »
    Those were my thoughts but I was too insecure to say it out loud. Looks like a power amp with those beasts in there.
    I guess I'm just more secure than you :D
    Main System:
    LSA-1 Statement
    SVS SB4000 & SB2000
    Secondary Rig:
    Analysus Plus Oval
    Backup Gear:
    Marantz SA-14S1
  • vcwatkinsvcwatkins Posts: 1,909
    I'll be very interested to hear what Rich has to say about upgrade paths. Nothing is certain, but I can't see ever letting go of my Joule. And I might be willing to invest a bit more in it if it makes a material improvement. For now, though, I'm very happily married to this thing.
    Den: Rega RP6 * AT33PTGII * Budgie SUT * Jolida jd9 * Roon (Sonic Transporter) * PS Audio DirectStream Jr. * Joule-Electra LA-100 mkIII * Sunfire Signature II * PSAudio Power Plant 3 * MIT S3 * Polk SRS 1.2
    Office: Roon * Sonore UltraRendu (LPS-1, WW Plat7, Iso Regen, Lush) * ProJect Pre Box S2 * Pass ACA * PSA Dectet * DH Labs Q10 * Brines Folded ML-TQWT RS 40-1354
    Beach: Music Hall MMF5.1se * Speed Box II * DL103r * Lounge Copla/LCRIII * W4S Sonos * Schiit Yggdrasil * Belles 20a Pre * First Watt F5 Clone * PSA Dectet * MIT S3 * Polk SRS 2.3tl
    Me, too. At the time, when I inserted the J-E into the system it made the single biggest improvement in sound quality in my stereo. My wife remarked about it from a couple of rooms away. The caps on that LA-300 are a big part of its $12k list price.
  • F1nutF1nut Posts: 42,665
    kharp1 wrote: »
    Mundorf MTube caps are excellent.
  • GlennDogGlennDog Posts: 2,029
    Yoda has spoken . . . Do Not disregard the advice
    Power Rogue M180 monos & Adcom GFA 5802
    PS Audio PerfectWave Power Plant 10
    Rears Salk SuperCharged Surrounds
    Source PSA PWT into NSD Supremo
    Pre/Pro Integra DHC 40.1
    LCD Samsung LN46B750
    Mains Salk HT2-TL
    Center Salk HT2C
    Pre Cary SLP-05
    Wires WW & MIT
    GlennDog wrote: »
    I humbly accept it with great reverence. Was hoping he would offer his opinion.
    Main System:
    LSA-1 Statement
    SVS SB4000 & SB2000
    Secondary Rig:
    Analysus Plus Oval
    Backup Gear:
    Marantz SA-14S1
    That LA-300 is a beaut.
    B&k 1430
    Tad 803 speakers
    Any news regarding the upgrade? My tech guy has told me that it’s time to recap my J-E, so I’m looking forward to what you and Rich end up choosing for capacitors.
    Haven't heard back yet. Feel like an expecting dad.
    Main System:
    LSA-1 Statement
    SVS SB4000 & SB2000
    Secondary Rig:
    Analysus Plus Oval
    Backup Gear:
    Marantz SA-14S1
    I can imagine. I’ll keep checking here. Good luck.
    kharp1 wrote: »
    Ya gonna hand out cigars when you get her back ? If so, I have a few requests. ;) :)
    B&k 1430
    Tad 803 speakers
    I think Kerry has something else or two that might mandate cigars over the Joule. o:)
    DSkip wrote: »
    Amen Skip, dude is on a role. The boy can move faster than Usain Bolt when he wants to.
    B&k 1430
    Tad 803 speakers
    I can't afford cigars, I'm freakin BROKE! I was happy with the ipod and headphones. How did I get so deep in this hole? I'm so ashamed I don't even recognize myself anymore! :p
    Main System:
    LSA-1 Statement
    SVS SB4000 & SB2000
    Secondary Rig:
    Analysus Plus Oval
    Backup Gear:
    Marantz SA-14S1
  • dromundsdromunds Posts: 8,230
    When ya recognize yerself again I’ll take a Cuban!
Howdy, Stranger!
