ppi amps
Systems
Systems Posts: 14,873
edited August 2001 in Car Audio & Electronics
Hi kim i have recently purchaced my two momo120's and i will be using a ppi amp pc21400 to drive them it is rated at 350w rms by 2 into 4 ohms and 700w rms by 2 into 2 ohms or 1400w rms by 1 into 4 ohms do you think i will get the best results by using the 350w rms by 2 into 4 ohms
thanks Stewart
Testing
Testing
Testing
  • rhythmdoctor
    rhythmdoctor Posts: 3
    edited August 2001
    Hi kim i have recently purchaced my two momo120's and i will be using a ppi amp pc21400 to drive them it is rated at 350w rms by 2 into 4 ohms and 700w rms by 2 into 2 ohms or 1400w rms by 1 into 4 ohms do you think i will get the best results by using the 350w rms by 2 into 4 ohms or should i run the mm120's into 1400w rms at 8 ohms which will sound better. I also have a pc4100 amp for running the two sets of mm465's splits that i will be running in the front and the rear do you think that this amp will do a good job running these splits also do you recomend the precision power products i understand that it is really good quality stuff?
    Thanks Stewart.
