SDA-2B interconnect cable
Looking for a SDA-2B interconnect cable.
  • agfrost
    agfrost Posts: 2,474
    Your 2B a pin-blade, or a blade-blade connector?
    Jay
  • I am looking for the same cable for my SDA-2Bs. In my case, it is pin & blade.
    F1nut Posts: 51,934
    Search Neutrik SpeakOn here.
  • Airplay355
    Airplay355 Posts: 4,298
    I used a run of speaker wire into the pin part. I think the blade part doesn't actually carry any signal so it might get you by until you're able to get a cable.
    audioluvr Posts: 5,982
    Wedding pic as his avatar... He's probably busy
