Power Amp to work with Polk Signature SRS 2 speakers
I tried using. Proceed amp3 ampmtoday with these speakers and I got a loud thumping sound ,I removed the cable that links the 2 speakers and the speakers played ,tried hooking the cable back and the speakers made the same noise.I hooked the speakers up to a Pioneer SX-3700 without any issues.
  • GlennDog
    GlennDog Posts: 3,149
    Not familiar with Proceed amp3 . . . is it a non-Common ground amp?
    This is very important
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    F1nut Posts: 51,664
    You got tbe noise because the amp is not common ground.
    Tony M Posts: 11,566
    Why didn't it fry something?
  • I guess I got lucky ,I hooked the amp up to another pair of speakers and it is playing without any issues.I used a Hafler dh-220 and that combo played with any noise.What amps have some of you have used with Polk speakers with the the special cable
    edited February 2018
    I'm using a NAD C370 or (C372?) Integrated with a set of SDA-SRS2's with great success for years now.
  • FestYboy
    FestYboy Posts: 3,861
    All SDA speakers require a common ground amp when using a standard interconnect cable. To verify if the amp you want to use is common ground, use a multi meter to check for continuity between the left and right negative terminals. If you do not have continuity, do not use that amp.
    F1nut Posts: 51,664
    Tony M wrote: »
    Different things happen with different amps. Sometimes the amp cooks, sometimes the speakers cook, sometimes both, sometimes things make weird noises.
  • Tony, I can't believe it didn't damage something,but I have been playing amp all day on another pair of speakers without any trouble.I have been playing the speakers using a pioneer receiver all drivers working without any distortion.
    I'm glad to hear that. Very glad.
    I've heard of some bad results here on the forum.
    I didn't know one could escape undamaged. Maybe you didn't continue to play them.
  • The second I heard that noise I shut the amp off,then I unplugged the special cable and the speakers played without issue I then hooked up my receiver and hooked the cable back up and everything was fine.
