Denon DP-2500A DIN to RCA
Hello All, I’ve been searching around scouring the internet for tonearm DIN connector to RCA. I’m not 100% sure if these are compatible. I found two cables and one converter. Do you have experience with these and/or used them with a similar type turntable to a Denon DP-2500a?
DIN to RCA interconnect
https://www.amazon.com/dp/B002A2U718/ref=sspa_dk_detail_0?psc=1&pd_rd_i=B002A2U718&pd_rd_wg=vu23M&pd_rd_r=VWMWPS2ZWXAAAN4VVK6K&pd_rd_w=7QUEj
https://www.amazon.com/gp/product/B01E7IQ6V2/ref=ox_sc_act_title_1?smid=A1FEN8WPYFT9YE&psc=1
Converter DIN to RCA Jack
https://www.musicdirect.com/analog-accessories/cardas-phono-interface-box
  • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
  • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
  • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
  • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
  • Office-2.1 B&W Formation Duo and Bass
  • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
  • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
  • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
  • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
  • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
  • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • Manticore
    @mpitogo You did not mention what tonearm you are using.
    As long as your "tonearm" has a five pin DIN plug on the bottom you should be golden. And the cable you purchase is long enough to reach the back of your Mcintosh, or Phono Pre Amp - of course!
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
  • mpitogo
    mpitogo Posts: 520
    edited February 2018
    @Manticore thank you. I took a chance and ordered the Pro-ject cable with a dL-110 and a few other accessories. It worked like a charm. Length is 1.23m, a bit longer than OE but fine and couldn’t be happier.
    From research it looks like there are at least two different kinds DIN to RCA tonearm cables. I used what looked to be the best match from images and looks like I have a winner.
