Audio Research LS7 Questions
Looking to upgrade my existing setup a little. Kind of on a tight budget so I was hoping to keep costs down to $500-600 to upgrade my preamp. I currently have a Carver 1.0 amp that has been fully restored with the MK2 upgrade. I can spend an additional $600 on upgrading an old C2 pre or do something else. Locally there is a AR LS7 available for $800 which is more than I wanted to spend but there is something to be said about only having to drive 10 minutes to look at something.
Is this thing worth looking into? No idea what is available as I'm just getting back into this...
Home System:
SDA 1C's - Full mod with the help by Dave...
800 Va Dreadnought- Speaker Interconnect
WireWorld Mini-Eclipse 7 speaker cables
Cambridge Audio Azur 851N - DAC/Streamer
B&K Reference 50 Pre/Pro
B&K M200 Sonata Monoblocks
BLE-Design 16mm Power Cables
Cambridge Audio DVD 99
Sangean HD FM Tuner
Barn system:
SDA SRS 2.3's Full mod done by myself
Carver C-1 pre
Carver M1.5t
BluDenso - Bluetooth receiver/DAC
  • tonybtonyb Posts: 30,768
    edited February 2018
    I wouldn't sink more money into the Carver. Lots of avenues to go down. There is a Maple tree tubed pre on US Audiomart that might fit right in.
    http://www.usaudiomart.com/details/649405257-mapletree-audio-line-2a-se/
    You can also use older high end HT processors as a SS 2 channel pre. Something like this....
    http://www.usaudiomart.com/details/649400448-anthem-avm-50-preamp-processor-xlr-rca/
    Would sound way better than the Carver in my opinion, plus you have the option of using the good dacs built into the Anthem.
    HT SYSTEM-2 channel
    Dynaudio Audience 72
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    Analysis plus crystal oval ic's
    B&k 1430
    Tad 803 speakers
  • Nice! Thanks Tony! Never thought about newer AV. That Anthem looks like a good unit.
    Home System:
    Sangean HD FM Tuner
    Barn system:
    Carver C-1 pre
    Carver M1.5t
  • SCompRacerSCompRacer Posts: 7,046
    dolsey01 wrote: »
    The LS7 was a very nice basic line stage preamp, but just be aware it's about 30+ years old so might need some capacitor replacements. If it's been serviced recently......
    Just thought it worth mentioning Audio Research won't divulge anything about service history like some companies will. Some manufacturers will divulge service history if you give them the serial number. Only way is for seller to provide receipt of work performed. Aside from that I like AR gear, have a Ref 3 currently.
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
    There's a Ref 5 on Chicago's craigslist for under 500.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    tonyb wrote: »
    Meet in a parking lot and get robbed? lol The 5's still fetch a high price, above 5,000. The Ref 5SE would be a nicer upgrade over a 3, but too much for me.
    https://chicago.craigslist.org/nwc/ele/d/audio-research-high/6491394207.html
    Says nothing about meeting in a parking lot Rich. Unless the dude forgot to add a 0 on the list price. Looks to be an older model anyway, not an SE.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
  • How are the newer Yamaha and Marantz Pre/pro's? Are they worth a look? There are lots of those available but that could mean they are junk too.
    Home System:
    Sangean HD FM Tuner
    Barn system:
    Carver C-1 pre
    Carver M1.5t
    Doubt you find a current Marantz pre/pro for the size of your budget.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    The Anthem I posted earlier is one of the better pre/pro's, sound wise, and better than most newer ones. This one is also good....
    http://tmraudio.com/product/cn1-50
    You can also find B&k REF 30 or Ref 50 for 200-400 bucks which will also make excellent 2 channel ss pre's. All I mentioned have exceptional dacs to use also built in.
    Just trying to stay in your posted budget, with something that will give you a sound quality boost over the Carver.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    Here's a list of pre's in your area....
    https://portland.craigslist.org/search/ela?query=pre+amp
    Type in B&k, and you'll see a couple steals, like a Ref 50 for 100 bucks. Has no remote but you can pick one up on ebay for around a 50.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    There is also an Outlaw 950 pre, in your area which is a nice sounding unit as well. If your more into vintage sounds, maybe look at the Sansui 717 or Sansui single digit receivers.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
  • Crap! Those are good deals !(hopefully). What do you look for with good DAC's. Is it newer than a certain year or something? I also saw an Anthem TLP1. Is that good?
    Home System:
    Sangean HD FM Tuner
    Barn system:
    Carver C-1 pre
    Carver M1.5t
    tonyb wrote: »
    Ah, SP 5. Reference 5's are a bunch more. From a Ref 3 to a Ref 5 isn't a big jump, but the Ref 5SE is.
    audioluvr wrote: »
    The TLP gets mixed reviews, some love it, some not so much.
    Depending on your source, using a processor, especially a higher end one, you have greater flexibility. You can use the dacs in your cdp, or the dacs in the processor. An option you don't have with a strictly analog pre amp. The pre amp sections on these processors are well built also and most retailed north of 2-3k when new.
    You also gain more level of control in tailoring the sound to your liking as most processors have numerous ways to do so.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
  • Looks like I'm going to go pick up the B&K reference 50 tomorrow after work. Looks like a sweet unit. Thanks for all the help!
    Home System:
    Sangean HD FM Tuner
    Barn system:
    Carver C-1 pre
    Carver M1.5t
    Cool, not much to lose there. You could resell it for twice as much. Start looking for a remote, you kinda need it for programing or it can be a tedious affair doing it manually by that small screen.
    Make sure it works too....that price is so low it warrants a bit of sceptism.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
  • kharp1kharp1 Posts: 2,619
    audioluvr wrote: »
    Be cautious on the 50, I have one sitting collecting dust. They have a known issue with software making it lock up. There is a company, the name escapes me (SMC maybe?) that does B&K repair.
    Main System:
    Joule-Electra LA 100 MKIII
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
    Dual SVS SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
  • Will do. This will be used for my 2 ch system
    Home System:
    Sangean HD FM Tuner
    Barn system:
    Carver C-1 pre
    Carver M1.5t
    Doesn't matter if it's 2 or 5 channel, it's completely software driven.
    Main System:
    Marantz SA-14S1
    Dual SVS SB2000
    Secondary Rig:
    Analysus Plus Oval
  • Thanks for the heads up. A Google search revealed a company called Stargate Electronics that bought all the B&K parts when they went out of business. Luckily I checked it out and it works great after spending 2 hours trying to figure out why there was no bass coming out of my speakers... Tons of contour features I had to wade through but I think I got them all turned off. Also was given a free Cambridge Audio DVD player.
    Home System:
    Sangean HD FM Tuner
    Barn system:
    Carver C-1 pre
    Carver M1.5t
    That the one. Trying to decide if I want to send my 50 in, or, just toss it in the dumpster that I'm suing while cleaning out my junk. I'm leaning towards tossing.
    Main System:
    Marantz SA-14S1
    Dual SVS SB2000
    Secondary Rig:
    Analysus Plus Oval
  • Just spent a couple hours listening to this thing and I can't believe how good it sounds! It's making my Klipsch KG4's sound almost as good as my 1C's! Can't wait to hear it with my 1C's. Hey if you toss it send me your remote. I don't have one
    Home System:
    Sangean HD FM Tuner
    Barn system:
    Carver C-1 pre
    Carver M1.5t
    audioluvr wrote: »
    Glad your digging it. Told ya bro....good sound on the cheap. Running it in 2 channel right ? Speakers at large ?
    The amount of adjustments to tailor the sound is almost....dare I say....too much. You'll never run out of inputs though, that's for sure. Rock on man.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    I might also add, if your inclined to do so, that the Anthem processor may be a better match with the Klipsch, and the B&k for the 1C's. The Anthem has an even smoother sound to it which may benefit the forwardness of the Klipsch. Just a thought....
    If your a happy camper, then leave well enough alone. Keep an eye out though, these higher end processors often come up cheap. I would highly suggest keeping an eye out for a Cary cinema processor, A Classe....but only for the 1c's, might be too forward with the Klipsch.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
  • This is my main 2 channel pre for my SDA 1C's (still waiting for the crossovers to come back). I think I am going to keep an eye out though to update my Sony AVR. Thanks for all the help!
    Home System:
    Sangean HD FM Tuner
    Barn system:
    Carver C-1 pre
    Carver M1.5t
Howdy, Stranger!
