Center channel for s60 towers
So looking for some advice. I purchased a pair of s60 towers which I love and have been running them with a paradigm cc190 center channel. I really noticed for the first time yesterday watching a movie the tonal difference between these speakers. I love the cc190 but now I am thinking of selling it and getting either the s35 or s30 center. The cc190 is a true 3 way so what do all of you suggest. As stated just looking for some advice. Thanks in advance
  • mdaudioguy
    mdaudioguy Posts: 5,164
    That's a decent speaker, but timbre matching is important. Either Polk will be nice. I personally like the low profile of the S35. One of my friends has the S60/S30 combo and it definitely sounds good. I don't think you can go wrong either way.
  • firsttimer
    Placement and size is not an issue so really undecided at this point but the timbre matching is not there with the combo I am running now. I have heard there are pros and cons to each Polk Center. Might try the s30 as it has the same size woofers.
  • firsttimer
    I am north of the border in good ol canada
  • firsttimer
    Did you not like the s30?
    txcoastal1 Posts: 13,519
    firsttimer wrote: »
    He's a dealer, and not much of an HT guy...2-chnl brother ;)
  • rburgess714
    I have the s35 and it is boxed in the closet. I would get the s30.
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
  • firsttimer
    What did you not like about the s35 compared to the s30?
  • firsttimer
    DSkip wrote: »
    txcoastal1 wrote: »
    firsttimer wrote: »
    Right. I simply don't have the space for them now.
    Not sure if you can answer this but have you heard either of these Center channel speakers. I am running two velodyne 10 inch subs that handle the bass so bass output is not an issue for the Center. I do like the full sound of the paradigm but I really noticed the timbre match and now it is really audible to me. Anyways thanks for any input. I guess I am going to have try either and see how it will sound and make sure if I do not like can return and try the other. Might be the best option. Thanks
    The s30 is going to sound a bit more fuller, simply because of the larger drivers. If you have the room to fit the larger size, I'd say go with the 30.
  • rburgess714
    firsttimer wrote: »
    While the 35 was detailed it just seem to be lacking the dynamics of more traditional centers with larger drivers. At low volume in scenes where actors where talking quietly or whispering I struggled to hear even with the settings at +6.
    I did not try the 30 but would think with the larger drivers it would perform better. I had a CSiA6 that was not in use and replaced the 35. The timbre does not match but it works for me for now. I am actually considering 30 myself.
    Living Room
    Office
  • firsttimer
    Thanks for all the input looks like toe 30 it is. Will pick one up this weekend. I will let you know my thoughts
  • firsttimer
    Thanks so much now I just need to find a s30 in stock locally seems all stores that sell them are out of stock
  • firsttimer
    firsttimer wrote: »
    Supposed to be picking up an s30 tomorrow so will let you know what I think
  • firsttimer
    Picked up an S30 this afternoon and hooked up to the home theatre. Ran Audyssey on my Denon avrx3300 and it set it to large. Did not realize it and thought it sounded a little flat. Changed it to small and what a difference. It matches the S60 towers wonderfully. The three speakers blend together very well. Dialogue is very crisp and clear. At this point I am very happy with changing out the paradigm to the S30. The front soundstage is much better now and the S30 has been a good addition. For all of you who are thinking of adding this Center so far I can recommend it.
  • mdaudioguy
    Awesome. Enjoy! :)
  • mrloren
    mrloren Posts: 2,474
    Yes the S30 is a nice center, enjoy :)
  • firsttimer
    Must say I am pleasantly surprised at this point.
