Cosmetic restorations of equip. Covers
Have a rt707 cover that needs refinishing (marks and surface rust) anything more involved than simple sanding and crylon????
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
    F1nut Posts: 51,951
    Krylon
  • verb
    verb Posts: 10,176
    That should work. Depending on how deep the rust is, you may have pit marks or other imperfections in the metal after sanding. To fix, you can use spot putty to fill em.
    nooshinjohn Posts: 25,985
    Take it to a body shop or a powder coater and let them do it any way you want it finished.
  • soundfreak1
    soundfreak1 Posts: 3,414
    Was going to use some 0000 steel wool. Just don't want a "modled" look
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
