Beautiful Marantz PM 15S2 Reference Series integrated amp w remote, phono ,box ,manual
geppy1
I have decided to change directions AGAIN so I am selling my Marantz PM 15S2 Reference Series integrated amp with remote, owners manual power cord and original box and packing. I have enjoyed this amp but now it must go.
The PM 15S2 is part of the Marantz Reference Series of highly reviewed and respected integrated amps. It is built like a tank at over 40lbs and looks and feels like the high end piece it is. Stunning in appearance. The PM 15S2 puts out a conservative 90 w/ch into 8 ohms and 140 into 4 ohms. It has 6 inputs including a special CD input, excellent MM/MC phono stage as well as 4 other inputs including 2 tape loops. The PM15S1 also has a preamp out . Other features are bass and treble with bypass, adjustable muting and balance and you can dim the display from the front panel or remote.. The remote can control other Marantz components as well as most PM 15S2 controls. The amp is in beautiful condition and everything works as it should. The sounds is pretty neutral. No disappointments here. Asking $995. Thanks
I don’t normally like silver front gear, but that is beautiful! The blue backlight on the middle section bump-out and the gold ring around the display are very well done and give it just the right amount of detail.
GLWTS Geppy. -
What's a "special CD input"?
Kind of makes the other inputs feel a little inferior, no? Aren't they "special", too? Walking a pretty fine line there, geppy1, in this time of participation ribbons, safe spaces, etc., don't you think?
GLWTS -
The CD input has different circuitry then the other 4 line level inputs. See the Stereophiile review of the Pearl version of this amp. They talk about the leaner tighter sound of the CD input Same applies to this version.
Nice specs on this bad boy:
bump
SOLD on AK
