Buy LSiM's and sell my SDA's?
Conradicles
in Speakers
For 5.1 H/T in my man cave. The prices of the LSiM's are great at this time. Here is what I am thinking of doing:
Currently have these:
SDA SRS 2 (fronts)
CS350-LS (center)
SDA-2B (rear)
Thinking of buying these:
LSiM 707 (fronts)
LSiM 706 (center)
LSiM 703 (rear)
I could sell my current system for around $750.
Adorama has the LSiM package for $2000. So out of pocket around $1250 for a new LSiM 5.1.
I already have a killer subwoofer.
Thoughts? Should I?
SDA SRS 2 (fronts)
CS350-LS (center)
SDA-2B (rear)
LSiM 707 (fronts)
LSiM 706 (center)
LSiM 703 (rear)
Thoughts? Should I?
I made the switch from 2.3TLs as mains. No regrets at all. At least for home theater use.
Wow no love for the LSiM?
yeah, make a 10.21Post edited by msg onI disabled signatures. -
Conradicles wrote: »For 5.1 H/T in my man cave. The prices of the LSiM's are great at this time. Here is what I am thinking of doing:
SDA SRS 2 (fronts)
CS350-LS (center)
SDA-2B (rear)
LSiM 707 (fronts)
LSiM 706 (center)
LSiM 703 (rear)
Thoughts? Should I?
Are your current speakers recapped, are the drivers dynamated, spiked and equipped with RDO194's? If not that would be my suggestions."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
I'd keep the 2Bs, AND seriously consider the LSiM package.
If you've ever wanted them, that deal's the deal.
Blink, and it might be passed.
Or maybe next time they'll be even less. I can't see how, though. They're literally at giveaway prices now.
I still can't get over the current deal. I was happy to pay F&F, couldn't afford them otherwise, but this deal is absolutely unbelievable. How much of an LSiM junkie am I? I don't need any more, but I was running through my list of friends I could try to convince.I disabled signatures. -
This, but with the LSiM 705's...a better speaker, all-around. IMHO, of course.
I haven't heard 707s personally, but yes, the consensus on 705s being better balanced is why I went with them.
As I write, I realize that I wonder which I would prefer had I the chance to hear both for myself. Related note/consideration - I love the 703s, but my understanding is that there are some flaws. If the 707s are like the 703s in their fat sound, I'd consider the 707s as long as they're not loose or boomy and don't require high volume to sound good.
One thing I notice with 705s is that it takes me more volume knob to reach the same listening output level as 703s. IIRC, another 5-6dB on the volume knob. Can't remember whether this is with or without the sub on the 703s. Due to the smaller driver set on the 705s vs the 703s?I disabled signatures. -
It seems to me you kind of want to make the switch. I did a similar update and in the end, it still sounds great, but the new LSiM speakers look so nice. I would say do what you want.Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808 -
Dooo it.
Never hurts to mix it up once in awhile, that's how we learn....sometimes.
lsi 9's -
Yes, I kind of want to make a change. The prices of the LSiM are really good too. I have a few different amps I can try on the 707. -
Conradicles wrote: »It seems to me you kind of want to make the switch. I did a similar update and in the end, it still sounds great, but the new LSiM speakers look so nice. I would say do what you want.
Then go for it, you've got the gear to make sure they will be powered so what's stopping you. You will end up with nice looking, sleek, great sounding speakers that could keep you happy for years. That's a win all the way around.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
You'll only regret not doing it, 'cause then you'll never know how it sounds to you. The current prices are great and much better than the F&F deal I used.Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra -
You won't regret it because you already have the better speakers.
President of Club Polk -
SDA SRS 2 (fronts)
CS350-LS (center)
SDA-2B (rear)
LSiM 707 (fronts)
LSiM 706 (center)
LSiM 703 (rear)
Thoughts? Should I?
The 2b's are stock. The SRS 2 have upgraded tweeters, Larry's Ring's and some other small mods. -
Seems like you could get more than $750.00 for the SDAs. If HT is the goal then yes, get the LSiM at that price.
HT is definitely all this rig is for. I have 2 other systems to listen to music.
Personally I'd leave well enough alone. I bet your current system sounds incredible for HT.
Can't comment on the swap as I've never heard any of the LSiM line. I can highly recommend the SDA's though. Not to bust this discussion, quick question, when using SDA's as a rear channel do you use the SDA interconnect cable? I would think you still would. Thanks.
All I can offer is this, I had 2BTL's and 1C's (both fully modded) and now LSiM 705's... and the end result is - I still have modded 2BTL's, 1C's and 705's. Once again, I feel my work here is done.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
You can never have enough speakers! Go for it but keep the SDA's and CS!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
aprazer402 wrote: »Can't comment on the swap as I've never heard any of the LSiM line. I can highly recommend the SDA's though. Not to bust this discussion, quick question, when using SDA's as a rear channel do you use the SDA interconnect cable? I would think you still would. Thanks.
Normally I would use the cable, but in this case, I do not due to a fireplace being between them.
It really does. Most of the time when viewing normal things I don't even turn on the subwoofer.
Only problem is that the SDA SRS 2 are a bit visually challenged LOL. And the LSiM 707 are so sexy.
This:
They are engineered quite well, aren't they?
I mean if you have the disposable income, the deal they are running right now is tough to beat.
I wonder how much the upper woofer's port tube resonates from the lower woofer's energy and if it is enough to distort the tune... Hmmm
If the sole purpose of that room is HT, do it. You'll have a killer HT.
Many of the deals are now on backorder. I have been on the fence too long.
