Has anyone modified SDA-2Bs to SDA-1Cs?
I'm thinking of adding two more bass drivers (one SDA one Regular)and an SDA tweeter after the upgrade. I'll modify the mounting board by placing the tweeters side by side and cutting new holes for the woofers. Any thoughts?
Best Answers
  • FestYboy
    FestYboy Posts: 3,861
    Answer ✓
    Won't be the same, enclosure volume is different, therefore throwing the tuning off.
  • Gerres26
    Gerres26 Posts: 874
    Answer ✓
    I would just buy a set of 1c's if thats what you want. You can always sell the 2b's to recoup most of the cash and you won't have to worry about ruining a perfectly good set of speakers in the process.
  • Rrusse11
    Rrusse11 Posts: 116
    Answer ✓
    SDA SRS 2.3s
    Pair of Carver TFM 35s
    Carver C-1 Preamp
    CAL Icon MkII CD
    RTA 12s, need major work
    pitdogg2 Posts: 27,325
    Answer ✓
    That's just silly talk!
    Cabinet is not large enough
    Crossover is not right.
    Cheaper to just buy a different set of speakers.
    Many think a fully modded sda2b set runs circles around the 1c
    The sda2b can be TL'd
    Answer ✓
    All good points ^^^^^^^^
    Plus....more drivers doesn't necessarily equate to better sound.
  • gmcman
    gmcman Posts: 1,860
    Answer ✓
    What size room do you have your 2B's in? Just curious on your setup, I had mine in a 13x28 room and they sounded great.
    I agree trying to modify your 2B's will result in a ruined speaker.
  • verb
    verb Posts: 10,176
    Answer ✓
    These Polkies can be a bit rough @gary_haskins ! Don't fret :smile: I own a set of 2B's, and recently acquired a set of 1C's that I'm completely modding. See my thread:
    I bought them for 3 hundie. Lot's of fun with the mods!
    http://forum.polkaudio.com/discussion/179960/another-1c-upgrade-path/p1
    BTW - Welcome to CP!
    F1nut Posts: 52,005
    Answer ✓
    Good to hear.
    Do the TL upgrade along with the host of standard upgrades including the Dreadnought. Your jaw will hit the floor.
  • headrott
    headrott Posts: 5,496
    Answer ✓
    @gary-haskins, I own a pair of 2B(TL'd) SDA's, a pair of 3.1TL's and a pair of 2.3TL's. If you are looking for more sound output, the best upgrade you can do is get some 2.3TL's. They are as 2B(TL's) on steroids.
Answers
