Sansui AU-222 re-cap completed
ALL212
ALL212 Posts: 1,664
edited February 2018 in DIY, Mods & Tweaks
I've had this little guy on my bench for maybe 5 years and just never got around to it. Channel balance was way off. Found someone had already been into it and just didn't finish. Main board got a full compliment of Nichicon caps and now it's back to evenly balanced.
The bad boys - one of the 1uf caps measured short. The rest measure about 50% high.
Hmmm... I lied. Looks like earlier I put some Black Gates in there.
Aaron
Enabler Extraordinaire
    SCompRacer Posts: 9,121
    ALL212 wrote: »
    Well, duh, some of them caps are shorter than others.... :D
    Nice work! Now that you got some bench space, maybe I can move some of my projects to it?
    What's the looks like burnt area C002 or is it an optical thing?
    pitdogg2 Posts: 27,275
    Nice job Aaron
    Rich for some reason i feel there was a bigger multi legged cap there.
    I was hoping he quit using that little butane torch to solder stuff.
  • cortico
    cortico Posts: 587
    Looks great! What do you think about the black gates?
  • ALL212
    ALL212 Posts: 1,664
    C002
    Sound effect needed - BWAAAAAAAAA
    Really not sure (unless it was just a standard) that a 4 legged cap was needed. Two legs for mounting (NC). That damn thing almost got the propane torch to remove it. It measures beyond my meters top setting of 2000uf so it's way off also.
    cortico wrote: »
    Black gates - since I usually film cap the universe (and made no attempt here) I'm sure they are fine but I have nothing to compare them to. The rest of the caps are Nichicon Muse, Fine Gold or the Audio KA's. Total cost was probably under $25.
    la2vegas wrote: »
    Nice work Aaron. Do you have any gear that you didn't put your own special touch on? Seriously I have a AU-517 that needs your magic touch. o:)
    Working on other folks' stuff...I have a standard warranty. "When the solder is solid the warranty is over". I don't mind frying my stuff but doing something stupid on someone else's stuff isn't my favorite situation and with these old amps a lot can go wrong. I'm really not a pro at this recap stuff. I suspect yours should be easier as it probably doesn't have much point-to-point wiring and uses connectors between boards and they can be removed without issue. If you're serious let me know.
    Aaron
    SCompRacer wrote: »
    C'mon Rich, you know he uses that torch to roast the marshmallows in his Hot Chocolate anyway. :)
  • cortico
    cortico Posts: 587
    Black gates are great, send them my way if you opt to remove them :)
    cortico wrote: »
    While i do not dispute the fact that Black Gates are great caps I often wonder since they have not been made in about a decade or more are we running up against age related problems?
  • ALL212
    ALL212 Posts: 1,664
    When you replace 50 year old caps with 10 year old caps I'm not running up against any issues. Especially since they have been completely unused until now.
    Unless you mean my age...in which case there are many issues :wink: .
    Aaron
  • cortico
    cortico Posts: 587
    If they test well... no reason to fear. Those black gate caps aren't original to this Sansui, I believe they are out of production since 2006 but relatively recent.
    cortico wrote: »
  • cortico
    cortico Posts: 587
    further to my post, I read the article below. It's funny my DAC as a load of them and the guy that sold it said, "never turn it off" :
    There is a specific nature of the Black Gate capacitors, that some people seem to overlook. If you are not familiar with BGs then you may experience a disappointment after you switch on a DAC with BG caps inside. The sound will be the opposite of what is described.
    The music will sound as if the treble has been removed, with sluggish dynamics and muddy bass. However, we can assure you that is a temporary phenomenon associated with unused BG capacitors. Basically, unlike all other caps available, the BG caps have graphite particles impregnated paper separator (dielectric) inside them. It takes a couple of days these graphite particles to form the conductive tunnels. The process is very similar to rechargeable batteries. Once the batteries (graphite tunnels are formed) are charged, the BG capacitors continue to improve approximating their best. The sound will open up and the bass becomes clearly defined with plenty of dynamics yet very smooth at the same time.
    Depending on the BG type, capacity and application, the initial stage of continuous BG running in time is about a week. The sound will continue to improve as long as the equipment is kept switched on. However, unfortunately just like with batteries, the process building up the charge is also reversible. If the rechargeable batteries remain unused for a prolonged period of time, they tend to lose the charge. So if you go on holidays for a week, you more or less would have to start from the beginning. That is unfortunately the only drawback that one has to live with.
    The upside is that the sound incomparably better than with any other capacitors we tried and we tried almost them all, vintage inclusive. Having mentioned the specific aspect of BG capacitors, please do not rush with the judgment before one week passes with your DAC being continuously being switched on. Leaving the DAC on permanently not only runs your BG capacitors in and ensures ever improving sound but also reveals the true potential of those capacitors.
    http://sw1xad.co.uk/technology_post/black-gate-capacitors/
    tonyb wrote: »
    And he won't share what brand of butane he uses..... :D
    ALL212 wrote: »
    C002
    This Elna 123Black Ball cap pre-dated Black-Gate caps.
    Oh, for your next project, use my
    ALL212 wrote: »
    .....Two legs for mounting (NC). That damn thing almost got the propane torch to remove it.
    After I borrowed Jay's Hakko 808 to recap the Krell KSL pre amp (that he now owns) I went out and bought me a Hakko FR-300. The KSL was like 42 caps on a fiberglass board.
    About 15 years out you can help me with this one...if we can see and hold stuff anymore...lol Krell recapped this one a few years ago.
    After buying it, I moved the two resistors in the soft start board so they don't cook the caps they were near...
    This was the result if you left them resistors in the OEM location - on the component side of the board. Not mine, from another fellows amp.
    Post edited by SCompRacer on
    ALL212 wrote: »
    cortico wrote: »
    cortico wrote: »
    I do know they are unused. I guess my worry was how they have been stored and whether or not they could have had dielectric dry out from not being used and or inferior storage.
    Good to know guys.
  • ALL212
    ALL212 Posts: 1,664
    SCompRacer wrote: »
    Oh...sure - look who's got the cool stuff! ;)
    SCompRacer wrote: »
    You're assuming I can hold this stuff still now! Beers don't even help much... :'(
    SCompRacer wrote: »
    After buying it, I moved the two resistors in the soft start board so they don't cook the caps they were near....
    Dat's HOT! I like it HOT! Just not that hot... :#
    Aaron
  • ALL212
    ALL212 Posts: 1,664
    Took the little guy into the office to try on this setup. Absolutely nothing fancy. Old PC running media monkey straight out the audio output to inputs on the amp, no dac...no nuttin'. Boston Acoustic A40 Frankensteins (nothing original) for speakers. The AU3900 was sounding pretty brittle.
    HORRY CRAP BRATMAN!!! Loudness on, bass up just a few notches, tweeter up just a hair.
    B)
    Aaron
    mhardy6647 Posts: 35,216
    ALL212 wrote: »
    Took the little guy into the office to try on this setup... Loudness on, bass up just a few notches, tweeter up just a hair.
    B)
    I am shocked. Shocked.
    https://youtu.be/SjbPi00k_ME
