Thinking of getting SDA 1C's..
Hi.
I'm new here.
I'm really considering maybe picking up some 1C's fourth gens.
I had a few question's. How hard are some of the mods for a rookie. I haven't even ever placed a tweeter. I would like to at least replace them with the upgrades. Been looking around for a good guide.
Or if By one knows of any fellow pokies near Toronto. I'm in Orangeville, Ontario. I would rather pay someone experienced to do some mods if possible.
  • verb
    verb Posts: 10,176
    Welcome @JasonCapa ! I've in the middle of a 1C upgrade path currently:
    http://forum.polkaudio.com/discussion/179960/another-1c-upgrade-path/p1
    All I can say is it's been lots of fun! Everyone here on CP has been very encouraging and helpful! Enjoy the ride!
  • lightman1
    lightman1 Posts: 10,797
    Your ears will thank you.
  • I pulled the trigger on the 1c's.
    I did the light poke of the woffers to see if all the drivers move and they do.
    They sound wonderfull, but I feel like I'm not getting the depth I expected. I was hoping for airy and depth.
    I read on the forums to unplug one speaker at a time with the interconnect left on and the cable seems to be drive the other speaker with the interconect still attached.
    I have them set up as suggested in the manual. I have a dresser in between but have pulled them out and in as suggested also.
    The speakers are also 100% original no upgrades.
    Any suggestions?
    F1nut Posts: 51,880
    edited February 2018
    SDA's do not excell at depth, they do excell at sound stage width and imaging.
  • PSOVLSK
    PSOVLSK Posts: 5,396
    Congrats on the purchase. Wish I still had my 1C's.
  • Faustin
    Faustin Posts: 1,151
    What are you using for the rest of your rig? Amp etc.
  • I'm using a Icon audio 20pp tube amp, schiit Modi 2 Uber multi bit dac and go on or hqplayer. My amp I feel powers them really good for the low rating.
    F1nut Posts: 51,880
    Jason, ideally SDA's should be driven by a high current SS amp. From personal experience, sure you'll get sound using a 20wpc tube amp, but they won't perform anywhere close to what they are capable of. You need at least 50wpc if using tube power, 100wpc is even better.
  • JasonCapa
    JasonCapa Posts: 10
    With a 100wpc or more should I get more depth and a airy soundstage and image?
    Post edited by JasonCapa on
    JasonCapa wrote: »
    With a as at 100wpc or more should I get more depth and a airy soundstage and image?
    Yes to some degree, but those traits come from more than just the amplifier. Everything in your system contributes to....or takes away from....those things.
    F1nut Posts: 51,880
    JasonCapa wrote: »
    It sure will help. The 1C's driven with a 20wpc tube amp sounded flat. They came to life with 50wpc.
  • Faustin
    I went from a 50 watt / channel tube amp to a 100 watt / channel to power my 1c's. Huge difference. They really opened up with the increased power.
  • Rrusse11
    Rrusse11 Posts: 116
    More power! Trust us, you won't regret it.
    SDA SRS 2.3s
    Pair of Carver TFM 35s
    Carver C-1 Preamp
    CAL Icon MkII CD
    RTA 12s, need major work
