Help Me Spend My $$$
I am always in this debate...crossovers on my 2Bs or REAL amplification?! I have always desired a Marantz Model 250 but do need these crossovers refreshed. I can only do one this year, I can do the other the next.
GAHHH
  • MrBuhl
    MrBuhl Posts: 2,419
    Tough one, IMO, a Marantz 250 is likely to need some refreshing too at this point won't it? If that's the case, I would do the crossovers first.
    If you're talking about getting something shiny and relatively new and going separates, I would do the amp.
    There, I managed to provide no solution and give two answers, my work is done.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    tonyb Posts: 33,072
    crossovers...
  • MrBuhl wrote: »
    I saw one on Ebay for $599 that was just serviced. I didn't go into the details of what was refreshed but will look again.
    @tonyb I know this is probably what I should do but I think of it like this. What if I have to put my 2Bs away or end up with a different pair of speakers until I have the REAL space for them. The money will not be wasted but won't be enjoyed, I know the crossovers will make the biggest difference in sound quality especially with my almost 20 year old caps.
    Would it be worth it to go cheaper on the crossovers (not Sonic Caps) and get maybe a Parasound HCA1500? I have a nice Denon Preamp in my closet that needs some deoxit but should be good besides that.
  • Conradicles
    Conradicles Posts: 6,345
    I would go less expensive crossovers and a new amp. Both problems solved. I have used Jantzen and Dayton caps with excellent results.
  • Emlyn
    Emlyn Posts: 4,735
    Personally, I would find a good condition Parasound HCA-1500 and wait on the crossovers or just make minor updates to them. Have the tweeters on the 2Bs been updated already? If not, that's where I would start.
  • smglbrth
    smglbrth Posts: 1,496
    If there is nothing spooky going on with your 2B's then definitely an amp. Tweeters are a must if you haven't done that already, so, that would be first, then the amp. My .02....
  • Emlyn wrote: »
    I did get some RD0 194s but both batches were bad and cause a resonance on certain piano frequencies. I put the SL2000s back in for now, kinda put off of the Rd0s due to bad experience. I don't want to drop another $90 for buzzing tweets.
  • MrBuhl
    MrBuhl Posts: 2,419
    edited February 2018
    If you hurry - there are still some Clarity caps out there for close out in the PX and ESA line, but the quantities are dwindling fast, my 2Btl's have Solen in the low-pass and ESA's up high and sound great IMO. Come to think of it, I might have some 12uf Clarity PX leftover at home I would give you. I'll check weekend after next and let you know if you're interested.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • I also plan on spiking the 2Bs as I lost a lot of bass reinforcement when going from a carpeted room to a wood floored room. I hope that will restore what I am missing.
  • MrBuhl wrote: »
    Bonus won't be in until later this month but I plan to go through Dave (DHS) to upgrade the crossovers as my soldering skills are how do I put it...non existent? Yeah that sounds about right.
  • Emlyn wrote: »
    Skip the RDO194's and rebuild the crossovers so they use RDO198's.
    SDA 2BTL's for the win.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • TNTsTunes wrote: »
    Emlyn wrote: »
    I know TLing them is advised, I will discuss with Dave when the time comes but I am seriously considering it.
    Viking64 Posts: 7,568
    Crossovers with built-in amplification or amplifier with built-in crossovers.
    Either way = problem solved.
  • Gerres26
    Gerres26 Posts: 874
    MrBuhl wrote: »
    I agree to go with the crossovers first. I was able to snag all of my clarity esa caps at like half off a little while back due to close out sales. Definitely made buying nicer caps a little easier on the wallet.
  • gmcman
    gmcman Posts: 1,849
    Crossovers.
    That way once you start changing components further up the chain, you will be able to hear what the end result will be.
  • dpowell
    dpowell Posts: 3,081
    If those are your long-term speakers then do the XOs. Those old caps are worn out. You'll be surprised how much better they'll sound overall including improved bass response with new caps.
  • dpowell wrote: »
    Oh I don't doubt it, I think the loss of bass response is placement (still 6 inches off the backwall but I have them 8 feet apart with a entertainment center between them) and my new room which is laminate wood flooring instead of carpet. I am hoping that spikes will help with this, if not ill just deal with it.
  • Maybe spend some of your dough on a powered sub?
    Spikes improve pretty much all speakers. Fact!
  • Slapaho wrote: »
    I currently have a Velodyne CHT12 in the mix so that's covered.
  • Update - Packed my crossovers up and getting them shipped out to @westmassguy today for some upgrades. Pretty excited to take this step and see what comes of it.
    tonyb Posts: 33,072
    Cool man, they're in good hands.
  • I plan on spiking these at the same time. Anything in particular I need to know about removing the riser and drilling the holes?
    audioluvr Posts: 5,927
    You could remove the base, use it for a template, cut you an insert and install it to make it flush at the bottom. Just a thought
  • audioluvr wrote: »
    I don't have experience with wood work or removing them ao I am more curious of it is held on my glue and I slowly and carefully pry it off with even distribution etc etc.
    Flip them upside down and post a picture. So we can see what you're dealing with
  • codycatalist
    codycatalist Posts: 2,662
    Waiting for the crossovers to be sent back, I started thinking about amplification more. I know B&K is highly regarded around here, I saw a B&K ST2140 for $200 recently, I read 140 watts into 8 ohms and I am sure it has plenty of current. Anyone have experience with this model or similar?
  • JayMX
    JayMX Posts: 455
    edited March 2018
    I run a ST1430 (it's three channel so I have one spare) on my SDA SRS 2’s and I really love the sound. Very transparent. I always wish for a little more umph, but what good is a rabbit hole if it isn’t deep...? I think the 2140 has very similar guts but some newer features like remote trigger balanced inputs and I'm not sure if it has gain pots but if it does that would be nice, mine doesn’t. Well built, simple design. Supposed to be 185wpc into 4ohms. I paid $150, so if you can get it for $200 I’d jump on it.
    Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
    Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
  • JayMX
    JayMX Posts: 455
    I recently reworked some SDA 2's that had water damage to one of the bases. I removed the base pretty easily. They had been glued on and there was one ~2” finishing nail driven through the base, centered on each side. I used my Dremel to remove a little wood around the head of each nail then used vice grips to get onto the nail head and they pulled out with some effort. I was then able to pop the old glue with a sharp (but careful) blow or two from a rubber mallet.
  • GlennDog
    GlennDog Posts: 3,152
    You are going to be SO HAPPY !!
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • codycatalist
    Got the crossovers and everything hooked up tonight. Time for the burn in!
