Tube -- and horns :)
mhardy6647
Doing some urban renewal on the ol' Frankenaltecs today -- I've had my dump find JBL 275 drivers/H5040 horns on line for the past week or so, just for fun (mostly). While the EMILARs were off line, I took the liberty of touch-up painting the patches of bare metal on them (and they do look better, IMO & FWIW).
Today, I put the EMILARs back. As long as I was doing anything, I also decided to install the nice pair of Altec 802D drivers I have (which I got from DNewma04 at AK, by the way and if memory serves) on 'em -- taking advantage of the gen-u-ine 1" to 2" EMILAR throat adaptors I picked up sometime last year from Jammin' Jersey (which, rather ironically, is in Southern California).
As long at the 2441s were loose, I thought it would be fun and even sort of worthwhile to snap a few pictures -- just an opportunity to compare the beefy 1" throat JBL 275 driver with the profoundly beefier 2" throat JBL 2441 driver. In a coupla photos, I tossed in a 2A3 for a sense of scale (more interesting than a ruler -- especially with the chance that a rogue 2441 might decide to steamroll the poor, innocent 2A3!).
Herewith, photos -- strictly FYI & FWIW.
DSC_0464 (2) by Mark Hardy, on Flickr
DSC_0455 (3) by Mark Hardy, on Flickr
DSC_0458 (3) by Mark Hardy, on Flickr
DSC_0457 (3) by Mark Hardy, on Flickr
Tube(s) and horns, baby...
DSC_0457 (3) by Mark Hardy, on FlickrTube(s) and horns, baby...
Very cool!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Insightful, laughs, and like.
Still having a hard time with scale. Would those terminals be similar to the size of 5-way binding posts?
If so, good God, man, where do you put these things, and... well, {hushed} how do they sound?I disabled signatures. -
Yes, similar to a normal binding post (a little smaller).
At my house, it is (sometimes) easier to find a 2A3 than a ruler
So, the 2441's about 6 inches in diameter. It weighs 25 lbs according a spec sheet available on line (see link below). I actually think these are heavier than that (but, no, I haven't weighed one -- yet).
16 ohm drivers with sensitivity spec'd at 111 dB per watt at 1 meter (installed on a JBL 2350 horn). Analogous to Rolls-Royce's old horsepower specification, that seems adequate.
specs: http://www.jblpro.com/pub/obsolete/2441.pdf
How do they sound? Both of these drivers sound good.
