Onkyo as 2nd amp
I have been Onkyo Sr607 running at 7.1 with all seven speakers hooked up for the surround-sound. On the 607’s sub woofer output I am running to a Onkyo sr606 with bi amping capability. I plan to run four 10 inch 8 ohm subwoofers, 2 to the front left and right and two to the bi-amp outputs left and right.
My question is would the 606 drive all 4 with equal power? Does it matter if I even use the bi-amp or can I simply use any other channel for that matter?
    F1nut Posts: 51,760
    edited January 2018
    Let me see if I understand you correctly. You have one AVR connected to another via the sub out and want to know if you can drive 4 subs with the second AVR?
    I'm trying to wrap me head around that, but my instinctive reaction would be no.
    Clipdat Posts: 13,095
    Gotta use the right tool for the job, and an AVR's amplifier doesn't seem like the right tool to drive subwoofers.
  • smglbrth
    smglbrth Posts: 1,496
    I tend to agree that this wouldn't work.
    Since you are looking to just power the subs you don't need a super expensive amplifier(s)...
    mhardy6647 Posts: 35,005
    Without thinking too hard about this:
    1) why not use powered subwoofers?
    2) you (the OP) might want to do some Googling/reading about distributed bass applications.
  • vmaxer
    vmaxer Posts: 5,120
    Well.....me thinks not so much.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Viking64 Posts: 7,547
    I don't think it will work, but saying that your home theater has 4 subs might sound cool to your friends. :p
  • daddyjt
    daddyjt Posts: 3,077
    Even if you can, it doesn’t mean you should. How big is your room? What kind of subs are they, and what type of enclosure?
    ― Aleksandr Solzhenitsyn
  • I built 4 transmission line speaker boxes for the four Kicker CompVr's.... the room is almost a thousand square feet and plan to put one sub in each corner of the room. Each box is 48 in tall 18 in deep and 12in wide. I built the boxes at the perfect resonating frequency for the subs.
  • That distributed bass thread was very informative. However why was the polarity on one of the subs switched?
