PSW-122
There is pair of 3.1tl's listed in my neck of the woods that could probably be bought for around $100. They need some TLC but the big problem is one of the passives is bad.
Does anyone have a SW-122 or know where I might locate one. I understand this is the only model that used that particular type passive. I have thought about proceeding and replacing with then12 inch passive from the 1C's but I am sure they are tuned a little differently and I really would,notkwant to spend the time and money and not do it right.
Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
  • Sea
    Sea Posts: 317
    Sorry. I should have type SW-122.
    EndersShadow Posts: 17,713
    edited January 2018
    For 100 I’d do it. Give it time and see if you can find a passive on CL or eBay, otherwise you can part em out and still come out on top (provided you can stomach parting them out).
