New AVR needed. Looking for advice.
maxward
in Electronics
I’m relatively new here and noticed that many members have pretty nice looking home theater systems. Mine is not as high-priority as my stereo, but okay. My elderly Yamaha AVR (HTR-5560) just gave up the ghost. I briefly thought about having a local technician look at it, but since it was bought the whole home theater landscape has changed (no HDMI inputs on it). So it will go to the electronics bin at the recycling center. My speakers are relatively efficient, so I’m not looking for more power. The Denon AVR-S730H at $429 is probably what I’d get, absent any advice to the contrary. Budget is $350 to $500, but could stretch it another $100 if there is good reason to do so. There is nothing on the local Craigslist or Audiogon that currently interests me. Thanks for any suggestions.
Mike
Mike
Best Answers
It's even cheaper on A4L: https://www.accessories4less.com/make-a-store/item/denavrs730h/denon-avr-s730h-7.2-ch-x-75-watts-networking-a/v-receiver-w/heos/1.html
... It's also not very good due to it's relatively low power output. -
https://www.accessories4less.com/make-a-store/item/marsr5011/marantz-sr5011-7.2-ch-x-100-watts-networking-a/v-receiver/1.html
https://www.accessories4less.com/make-a-store/item/denavrx3300w/denon-avr-x3300w-7.2-ch-x-105-watts-networking-a/v-receiver/1.html
https://www.accessories4less.com/make-a-store/item/yamrxa1040bl/yamaha-rx-a1040-7.2-ch-x-110-watts-networking-a/v-receiver/1.html
Here are a few better choices.
Answers
Thanks for the suggestions! I was not aware of A4L.
It's a little secret that we like to share with people looking for AVRs for cheap
Let us know what you end up going with
A4L mostly sells refurbs which come with a limited warranty. Could be a better choice than buying used. If you want new, the Denon 2300 model is in your price range while they clear them out for the new model that didn’t change much...
https://www.amazon.com/Denon-AVR-X2300W-Channel-Receiver-Bluetooth/dp/B01E69LWWA -
Thanks. I’m not sure if refurbished would scare me off, but it’s good to know.
I have purchase several AVR's from A4L over the past few years with zero issues. If you catch them at the right time you can find some really nice receivers at some really great prices.
Thanks, ZLTFUL and D’prived. That’s good to hear. I’m likely going to give A4L a try. The choices are somewhat bewildering, despite the fact that they don’t carry all the brands I’d consider, like NAD and Sony. Online “reviews” and manufacturers’ websites are marginally useful. It’s as if last years model no longer exists, so not always easy to figure out what’s new and whether it matters. Plus, I’m hopelessly uninformed about the latest trends and technologies.
I can comment on the Denon avrx 3300 which I am currently using it is a very nice and capable receiver. My sister in law is running he avrx 1400 and my son is running the avrx 1400h this years model. They are all very nice receivers and should suit you well for years to come.
Thank you, firsttimer. Denon and Marantz are both on my short list. I need to decide if Heos is worthwhile. If so, then only the latest models make the cut.
I personally do not think Heos is any type of deal breaker.
This week Fry's promo code the Denon 4400 is $899. A lot out of your budget but a great deal on a monster aVRWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
Thanks. I checked their promo page on their website and it was $1199. Maybe they realized it was a mistake.
I have never had an issue with 3 Yamaha receivers I've purchased in the past. My next one will be a Yamaha when I get one with Dolby Atmos.
For $599, I think you would be extremely happy. That would be my vote for you!
https://www.accessories4less.com/make-a-store/item/yamrxa1050bl/yamaha-rx-a1050-7.2-ch-x-110-watts-networking-a/v-receiver/1.html#!specificationsSpeakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Yamaha RX-V3800 Receiver
Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable -
Thanks @GospelTruth and others for the advice and for informing me about A4L. I was not really considering Yamaha since it was my Yamaha that quit on me without any apparent reason. Also, there were too many different Yamaha models at and close to my original budget. Confusing to say the least. Then I looked at the RX-A1050 you suggested. I ended up ordering that model, their last one it turns out. I noticed that the layout of the back panel was a little neater than the cheaper models. Also, it’s over 10 pounds heavier than any of the others I had been looking at. I’m guessing that companies don’t add weight to AVRs without good reason, and this probably results in a more robust power supply, chassis and heat sinks than the cheaper models. Should arrive next week.
Looking forward to hearing your impressions.Thanks @GospelTruth and others for the advice and for informing me about A4L. I was not really considering Yamaha since it was my Yamaha that quit on me without any apparent reason. Also, there were too many different Yamaha models at and close to my original budget. Confusing to say the least. Then I looked at the RX-A1050 you suggested. I ended up ordering that model, their last one it turns out. I noticed that the layout of the back panel was a little neater than the cheaper models. Also, it’s over 10 pounds heavier than any of the others I had been looking at. I’m guessing that companies don’t add weight to AVRs without good reason, and this probably results in a more robust power supply, chassis and heat sinks than the cheaper models. Should arrive next week.
I think you'll be happy with it. I stay away from the lower end Yamahas. Not that they are necessarily bad, but I don't think they have the same build quality as the others. All mine continue to function.- I have an RX-V2095 from 1998 that is still in mint condition and just keeps on chugging. I have that one connected to our living room TV.
- I have an RX-V3800 for my theater that still runs like a champ as well - circa 2005.
- Finanlly, I have another RX-V1 I picked up for $200 6 years ago to use as a beginner amp/preamp with my SDA 2Bs. That thing is built like a tank as well and I see no signs of that dying. I use it as a preamp with a Parasound 2250 now.
As with all electronics, make sure you have some good surge protection/voltage regulation if you can. I think this helps keep your electronics from ending life prematurely.
Looking forward to your review once you get it.Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Thanks, again, @GospelTruth and others. I spent more than I planned, but this is a very nice AVR for $600. Many improvements over the old Yamaha.
