Amp stands
soundfreak1
Considering building a pair of amp stands. What materials would be best for construction? Ie: solid wood, MDF, ect. Also feet, spikes ect. They will be supporting a Krell amp and a parasound 1500a if this makes any difference.any input would be appreciated as this is my first foray into amp Stands.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
I do have some isolator matting for high sensitivity lab equipment that I use for my turntable I guess I've got plenty to use for under the amps if necessary but just curious about materials as to what would be the least offending material to build them out of?Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Hmm mm there is a guy that works acrylic not far from me, can ck prices. Probably mdf 3/4" might do the job.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
I utilized Butcher Blocks/Cutting Boards for my Stands and made a Base for them. Pretty simple stuff. I haven't gotten around to Spiking them though.
That's a nice look.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
