Carver M 500t amplifier common ground?
SWHALEN
SWHALEN Posts: 14
edited January 2018 in 2 Channel Audio
Hello, i was wondering if anyone has any information on using a Carver M 500t amp with a set of SDA 1c's. I have recently acquired one and thought about using it.
    pitdogg2 Posts: 27,047
    edited January 2018
    Some had inverted channels. I believe this is one
  • SWHALEN
    SWHALEN Posts: 14
    I've been poking around a few websites and not finding the answers i need. i see on the back it has "non inverting" connections and mono connections? I know my 1c's have pin connector if this helps.
    tonyb Posts: 33,072
    I believe it is not.
    nooshinjohn Posts: 25,925
    It is not. I had one connected to SDA 2b in the past and they hated each other.
  • SWHALEN
    SWHALEN Posts: 14
    Thanks! Yep its not looking like a good fit, I was hoping someone had a way around the Carver ground issue. I've be told i can run the Carver, without the interconnect cable hooked up to the speakers? But that kinda defeats the purpose of having SDA's. And i don't want to kill both amp and speakers. I have the Carver hooked up in the basement using a Luxman R 1070 for a preamp and some ADS L810 speakers as a test set-up, it may have to stay there. I guess the next question would be does the Lux sound better on it's own without the Carver?
    Tony M Posts: 11,623
    edited January 2018
    I loved my Luxman R-1030 so much I bought another one off of Ebay. But that was years ago! God, I wish I still had them. The sound was warm and POWERFUL for 30 watt'ers. They made my Polk Monitor 10's sound AMAZING.
    Take the Carver out and see. I'd love to here the Luxman / ADS combo!
  • daddyjt
    daddyjt Posts: 3,081
    edited January 2018
    All Carver M500(t) amplifiers invert one channel, thus rendering them NON-common ground. The M1.0t can be had in both common ground (about 70% of production) and non-common ground (the remaining 30%).
    The “non inverting” writing you see on the back panel is in reference to the LEFT channel. The RIGHT channel is always inverted on that amp.
    You CAN run the M500t WITHOUT the interconnect cable between the speakers, with no fear of ill effects - however, as you pointed out, this will not give the SDA benefit.
    There is no way (realistically) to convert an M500(t) to common ground.
    ― Aleksandr Solzhenitsyn
  • strider
    strider Posts: 2,568
    Had a pair of blade/blade SDA 2B's powered by a Carver M500 for years. Polk had a work around to allow using a non-common ground amplifier called an AI-1 interface cable. It was basically an isolation transformer built into an SDA interface cable. I don't recall if the AI-1 is compatible with 1C's or not, but it worked in my scenario.
    Wristwatch--->Crisco
    F1nut Posts: 51,770
    Hi Ben
    F1nut Posts: 51,770
    Ben is correct, the AI-1 or Dreadnought will allow you to use non-common ground amps including the Carver with pin/blade SDA's and a few early blade/blade 2B and 1C's.
  • lightman1
    lightman1 Posts: 10,796
    strider wrote: »
    It's about danged time you showed up, Ben. Dreadnaught....
    F1nut Posts: 51,770
    Nah, Ray coined it Dreadnought.
  • lightman1
    Viking64 wrote: »
    lightman1 wrote: »
    I was just thinking that Ben had an option. Don't be a peckerface Jesse.
    Russ, could you please keep your perverted sexual fantasies to yourself? :p
    I have yet to unleash the full on Lightman trolling upon you. I have made sycophants leave and never come back......
    Viking64 Posts: 7,551
    edited January 2018
    lightman1 wrote: »
    Make it fappen!
    audioluvr Posts: 5,915
    What's weird is I bought the M500t and SDA 2B's new in '87 and played it hard and loud for over 20 years without a hitch with either before finally selling it to upgrade to a home theater system. They must have built some that were common ground. If I remember correctly if there is a mono/stereo switch on the back it is common ground in stereo mode
    edited January 2018
    daddyjt wrote: »
    Like this. Only this is a 1.0 (not my work. Mine would probably have automotive jumper cables...)
  • daddyjt
    audioluvr wrote: »
    daddyjt wrote: »
    I’m glad that’s not your work - there’s so much wrong there, not even sure where to start... :neutral:
    daddyjt wrote: »
    All I know is it works!
  • daddyjt
    I am sure it does, and I meant no offense. In retrospect, my comment was harsh, and I apologize. I am an avid Carver tech, restoring and modding Carver gear for several years now. What does the daughter board behind the main filter caps do?
    Also, there is a simple service bulitin to move the blue and dlack wires above the filter caps to lower the noise floor. See photo. Also, consider replacing R227 & R228, as well as ZD101 & 102, and standing them off the board to help with heat dissipation. This is a common area of concern in the inverting 1.0t.
    This was an inverting amp. Blue and black wires were moved. As for the other questions, I have no answer. Though I am fascinated with electronics, my skill level beyond flipping the on/off switch and rotating the volume control is quite limited
  • strider
    Hi Ben
    Hey Jesse. Had a really good root beer last weekend from a place called Woodstock Brewhouse in Woodstock VA. It's about 20 minutes south of Winchester off of 81. Decent BBQ also, but only on the weekends.
