This should be fun!!!
Toolfan66
Toolfan66 Posts: 18,168
    EndersShadow Posts: 17,719
    Just cant leave well enough alone, can you :smile:. Gotta put that special "Larry Touch" on everything lol
    pitdogg2 Posts: 27,277
    New downspouts?
  • TNTsTunes
    TNTsTunes Posts: 751
    Speaker stands???
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • gmcman
    gmcman Posts: 1,859
    Uber soundbar?
    TNTsTunes wrote: »
    Speaker stands???
    Yep, speaker stands for my LSiM 703’s..
    1/2 inch aluminum plate, and 2” x 4” x 1/4 wall aluminum tube. My plan is to have adjustable spikes, and a plug on the bottom to fill it with sand or lead shot..
    The top plate is the exact profile of the 703 but it is a 1/4 inch bigger all around. They will be 23-24 inches tall with the spikes..
    we have different ideas of what constitutes "fun". :)
    nice job so far.
    Tony M Posts: 11,697
    Nice start!
    How about a shaft to hide and channel the wire thru?
  • TNTsTunes
    Toolfan66 wrote: »
    TNTsTunes wrote: »
    Speaker stands???
    Sweet.
    Are you going to run some beautiful TIG welds on them to hold them together?
  • FestYboy
    FestYboy Posts: 3,861
    @Toolfan66 you're a sick, sick man. ;)
    Viking64 Posts: 7,620
    Where's the hole for the Alexa device to fit in it?
    Brian going to get some TIG duty on these?
    Clipdat Posts: 13,100
    Finally stands that have a large top plate to match the 703's size! Fantastic!
    Toolfan66 wrote: »
  • Dabutcher
    Dabutcher Posts: 2,606
    Are you going to fill with sand or shot? Very nice design skills you have. Are you going to polish the aluminum? Good luck. D
    No I will do the welding, Brian will do some machining when, and if we can squeeze in the time, we are the busiest we have ever been the last few months, we can’t keep up with demand..
    Dabutcher wrote: »
    Not sure on sand or shot, will more than likely paint the stands..
    nooshinjohn Posts: 25,992
    tonyb wrote: »
    nice job so far.
    Italians have more fun making shoes out of wet concrete.
    tonyb wrote: »
    nice job so far.
    Yeah well...they last a lifetime, as short as that life becomes. :)
    Larry,
    Seeing your choice of material begs me to question if you considered the resonance. Aluminum I would think, rings like a bell, especially being hollow. Thoughts ?
  • FestYboy
    tonyb wrote: »
    Larry,
    Once filled, especially if with shot, those resonance should no longer exist.
    FestYboy wrote: »
    tonyb wrote: »
    Larry,
    True in theory, but you also have the metal to metal between the top plates, columns, and bottom plates on the outside. If it isn't as tight as a 40 year old virgin, you still may get some resonance.
  • Dabutcher
    I was thinking along the same lines as Tony. Maybe some rubber or felt between stands and speakers? Good luck. D
    I'm not too worried about resonance as the material is 1/2 inch thick T6 6061 aluminum, they will be pretty stout even without sand or lead shot. I will more than likely still put the little rubber feet on the bottom of the 703's..
  • stainless0steel2
    stainless0steel2 Posts: 193
    edited January 2018
    We oughta do a minimal profile of the plates to clean up the laser cut. Maybe even a radius????
    Toolfan66 wrote: »
    The Night is Dark and Full of Terrors
  • TNTsTunes
    Toolfan66 wrote: »
    If needed some dynamat extreme under the base and on of the top of the speaker stand. The rubber feet could be mounted to the top of the stand instead of on the speakers also. This should eliminate the chance of any resonance.
    txcoastal1 Posts: 13,519
    You could line with card board before loading?.?...just an idea
