no bass 3.1tl
ps4y2ch0
ps4y2ch0 Posts: 33
edited January 2018 in Troubleshooting
greetings! ive found a pair of 3.1 tl's upgraded with sonicaps and some kind of new resistors and other things. i ran them for years but not in at least two now. when i swapped them in yesterday, the right channel had zero bass at all. i have removed every driver and checked for lose wiring and tgere isnt any. visual inspection of crossover was good, nothing broken anyway. where should i start poking atound to find the fault and on what setting should the multimeter be on? im pretty new at this. thank you and im sorry if this is not in the right forum
Best Answers
    Viking64 Posts: 6,686
    Answer ✓
    ps4y2ch0 wrote: »
    5 6.5's coupled to a 12" passive. why a goose? youd have better luck with an african swallow...
    Ah, I see. In my TL brochure, they look different than the 1.2's and 2.3's. Like a conventional driver.
    I have never had good luck with "African swallows", but that's another story, not suited for this website during "Family Hour".
  • dkfreebird
    dkfreebird Posts: 1,182
    Answer ✓
    Have you checked the jumpers on the back of cabinets?
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Monitor 4 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino Rogue Magnum 66 pre
«13
Answers
    pitdogg2 Posts: 24,577
    Torn midwoofer surround, or cabinet air leak would be my first thought.
  • FestYboy
    FestYboy Posts: 3,861
    Did you check for magnet shift? IIRC the 3.1s are 6ohm.
  • ps4y2ch0
    theres no leak or torn surround. none of the drivers are receving low end signal. i figured it must be crossover related. all good places to start though. i have no clue how to check for magnet drif. i have multimeter but dont know how tobuse it yet
    I thought the 3.1's weren't passive? Maybe that is irrelevant, though. *Shrugs shoulders and uses a goose as a boomerang to the delight of eleven drunk Shriners in space suits.*
  • ps4y2ch0
  • FestYboy
    "...Yes, but what also floats in water?"
  • ps4y2ch0
    dkfreebird wrote: »
    yes i did they are hot glued on the inside and not feeling to lose at the post. how would i check that with multimeter
  • dkfreebird
    edited January 2018
    I’m talking about the jumpers on the posts. Are your speaker wires plugged into the top post or bottom post? If they are in the top plug them into the bottom post and that will tell you if it is internal.
    Oppo 103
    Pangea PC
  • ps4y2ch0
    yes the jumpers on the inside are tight as are the internal speaker wires and its all hot glued to stay that way.
  • dkfreebird
    Did you try the speaker wires on the bottom posts on the outside of the speakers?
    Oppo 103
    Pangea PC
    ps4y2ch0 wrote: »
    He means the jumpers on the outside.
    Tony M Posts: 11,017
    edited January 2018
    I found the answer to NO BASS on a few occasions. 2 were mine, one was a friends goof.
    The + wire HAS to go from red to red.
    - wire then goes from black and black.
    If you don't get bass after checking the above, I can't help you except see if your receiver is sending the bass to a sub output.
    Good luck to you. You've got an awesome speaker set there!
  • ps4y2ch0
    im running pre straight into tube power amp, no sub. wiring is all correct. thanks for trying
  • ps4y2ch0
    there are no outside jumpers because its done inside via nice wire
  • headrott
    headrott Posts: 5,484
    ps4y2ch0 wrote: »
    If that's true, I would verify that the wires inside (on the binding post cup) are in fact "jumpered" correctly. It is very unusual for them to be jumpered on the inside of the speaker binding post cup. I guess the previous owner and yourself never plan(ned) on doing bi-wiring?
  • ps4y2ch0
    i dont mind bi-wiring, but correct about the previous owne. i am contemplating chipping out the hot glue just to verify tightness on all the posts. to answer an earlier comment i hook up to the bottom two posts as recommended. and yes its wired correctly because it worked perfectly for years and havent changed a thing. i just wish i knew how to use this multimeter to check for solder issues
    There are two sets of outside binding post so therefore one needs to have a jumper in place outside between the upper and bottom red and black posts. See picture in ebay link
    https://m.ebay.com/itm/Pair-of-Audiophile-Polk-Audio-SRS-3-1TL-Speakers-Made-in-USA-Matching-Pair-/222223597464
    headrott wrote: »
    ps4y2ch0 wrote: »
    Boom 100% agree with this^^^^^^
    Unscrew the binding post cup and show us a picture of the inside. There will be no need to remove any if the glue we will be able to tell right away.
    F1nut Posts: 49,801
    Yep, we need pics. Inside and out.
    You didn't say if the drivers moved in and out on that right tower. Could some be frozen now?
  • ps4y2ch0
    previous owner was very proud of his glue gun
    ps4y2ch0 wrote: »
    I am very proud of my "glue gun".
    edited January 2018
    Get the polyfil out of the bottom. It should only be behind the woofers no where near passive radiator. Yes they are jumpered inside. BUT that is not something i would of done.
    I've never understood why someone would spend all the money on good caps yet not change or skimp on the resistors.
    F1nut Posts: 49,801
    edited January 2018
    ps4y2ch0 wrote: »
    That's a real mess!
    Try swapping crossovers to see if the problem follows.
    I have to add.....only an idiot would jump the posts internally.
    How about just the speaker wires from the amp first?
  • ps4y2ch0
    already swapped speaker wires, and swapped rca's to be sure. does anyone know what a multimeter should read at the binding posts?
