Shop progress...
steveinaz
steveinaz Posts: 19,546
edited January 2018 in The Clubhouse
The 16 x 24 shop is done, now I'm insulating, sheathing, and building the storage loft (24 x 4):
Now I need to build a workbench, and 2 - 72"hx48"wx24"d storage shelves.
PS: The pool just needs plaster and fill! I'll post pics when it's filled. This coming Tuesday is plaster/fill day.
  • vmaxer
    vmaxer Posts: 5,121
    Looks great!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • polrbehr
    polrbehr Posts: 2,851
    If my back yard had room on the flat area, I'd seriously consider building one of those. Looks great Steve, can't wait to see the pool.
  • charley95
    charley95 Posts: 908
    Great looking shed! When I built my workbench I bought a granite look Formica countertop at Menard's. It works really well and easy to clean.
  • Jstas
    Jstas Posts: 14,996
    Nice, dude.
    Hey, I gotta build some shelving in my garage! Wanna come help?
    It's a bit bigger, though.
    Expert Moron Extraordinaire
  • afterburnt
    afterburnt Posts: 7,892
    Nice Steve, how much did that det you back and where are you in AZ?
  • steveinaz
    afterburnt wrote: »
    Down in Sierra Vista. The shop cost with options (windows, 50amp ckt, all outlets ran + a 20amp dedicated outlet, and lighting) was $16k. I spent about $600 on insulation, and the loft lumber/hardware was maybe $300. Sheathing is 9/32" and probably will end up being about $250 to do the interior walls.
  • NotaSuv
    NotaSuv Posts: 3,871
  • afterburnt
    steveinaz wrote: »
    afterburnt wrote: »
    Dang, I am gonna have to bare bones mine and hopefully live long enough to finish it. And dang AZ is big, you couldn't be further away from me unless you were in MX lol.
  • steveinaz
    We're about 15 miles North of Mexico.
    Viking64 Posts: 7,627
    steveinaz wrote: »
    Ah, that explains the wall around your pool. :p
  • MrBuhl
    MrBuhl Posts: 2,419
    Looking good!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
