Is a B&K EX4420 a common ground amp?
Just wondering if I can use this with the blade/blade SDA SRS 2's I'm picking up tomorrow.
"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life."
  • TNTsTunes
    TNTsTunes Posts: 751
    I just checked the B&K 200.2 that is replacing the 4420 in my main system tomorrow and it reads .2ohms on the 200ohm scale when reading from the l to R speaker grounds. It appears that it is a common ground amp, hopefully the 4420 is too. I'll check it once it's out of the system.
    If not I'll use my Halo A23, I just like that B&K amps sound. I could use my B&K ST2140 too I believe.
  • Nightfall
    Nightfall Posts: 10,083
    It is. I've used my 4420 with both 1.2's and 2B's without issue.
    afterburnt wrote: »
    Village Idiot of Club Polk
