Budget Receiver with Phono and Bluetooth
rburgess714
in Electronics
Would like to build a budget 2 channel system for a friend. She has an old sony ps-t2 turntable that appears to be in good shape and a collection of vinyl that hasn't been played in 20 yrs. Looking for suggestions for a receiver or integrated with phono and bluetooth would be a bonus or an optical input to connect chomecast. She is not an audiophile so entry level gear is more than sufficient. Used is fine and would like to find a unit under $200. Will also be looking for some cheap bookies. Thanks in advance for your suggestions.
RB
RB
Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables
Office
I don't know what you'll find new in the under $200 category that has a phono preamp. You might have to get an external one.
https://www.bhphotovideo.com/bnh/controller/home?A=details&O=&Q=&ap=y&c3api=1876,{creative},{keyword}&gclid=EAIaIQobChMIwa6VhqK72AIVD8JkCh23xQTeEAQYBCABEgIGvvD_BwE&is=REG&m=Y&sku=1246224
Get this and maybe look on Craigslist for Monitor 5/7's and find an external phono preamp.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
That little receiver doesn’t look bad for this scenario.Living Room
Office
Douglas Connection ICs and Cables -
I bought a used Pyle Hybrid receiver a year ago and was quite impressed when I hooked it up to my JBL pros. This link is to a similar one. Affordable audio !
Sorry, this one doesn't have a Phono input.
I'm not sure about mine. I'll check the web now.
https://www.overstock.com/Electronics/Amplifiers/24804/subcat.html?featuredproduct=11041467&featuredoption=17045215&cid=225772&kid=113194307315267&track=BingPLA&utm_medium=cse&utm_campaign=bingpla&utm_source=bingpla&countrycode=US&gclid=CIGkjfvTvNgCFUaygQod3RwIEw&gclsrc=ds&dclid=CMOGkPvTvNgCFUR3wQodq2sNJg
The one I bought doesn't do Bluetooth or phono . This was cheap but it is powerful. How long it will last is another issue.
https://www.bhphotovideo.com/c/product/859936-REG/Pyle_Pro_PT270AIU_PT270AIU_600_Watts_Stereo.htmlPost edited by Tony M onMost people just listen to music and watch movies. I EXPERIENCE them.
Harman Kardon HK3490
Used for under $200
Seems like it would be perfect for her scenario. I had one and absolutely loved it.
From Home Theater Review..."It delivers a robust 120 watts per channel into eight ohms (150 wpc into four ohms).
Its rear and front panel provide seven analog audio inputs, including a phono input for those listeners who want to enjoy their vinyl (the phono input accommodates moving-magnet phono cartridges).
It includes coaxial and optical digital audio inputs - ideal for users with older CD and DVD players that might get better sound from utilizing the up-to-date D/A circuitry in the HK 3490.
The receiver has four composite video inputs and a dedicated input for the Harman Kardon The Bridge II iPod docking station. This latter feature enables you to connect an iPod via The Bridge II (sold separately); the iPod can then be controlled from the HK 3490's remote control and menus that are displayed on a connected TV or on the receiver's front panel."2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
per the above: I would never argue against an hk component (even modern ones).
Other thoughts (not necessarily useful, but thoughts nonetheless).
There's a low-end Yamaha receiver that has Bluetooth - but no phono preamp. Folks seem to like these. A decent budget phono preamp could still be added and remain under budget, methinks. I still like Yamaha stuff, as well (FWIW).
https://www.crutchfield.com/p_022RS202/Yamaha-R-S202.html?tp=47041
EDIT: Derp -- Nightfall already mentioned this one! Consider this a second of the motion, then!
There's an Onkyo with phono that's just 200 smackers (Crutchfield price). I know nothing 'bout this one, though.
https://www.crutchfield.com/p_580TX8220/Onkyo-TX-8220.html?tp=47041
There are also cheap Sherwood receivers with phono inputs. I'll leave it at that
There are add-on Bluetooth thingies to retrofit some sort of Bluetooth capability onto an old (or simply non-BT) component. Again, that's about all I know about that, too!
https://www.parts-express.com/sure-electronics-battery-powered-bluetooth-wireless-audio-receiver-with-power-supply-black--320-355
I own a prior iteration of that receiver. I couldn't recommend it unless they've made *major* improvements to the phono section.
It's atrocious. -
Wow, lots of choices in this range, I'm surprised what you can get for 200 bucks!
In case you happen upon a receiver you like that doesn't have Bluetooth, you can add a third party device after. In my early days, I had a couple of these IOGEAR Bluetooth receivers for playing music from a tablet or mobile on receivers that didn't have Bluetooth. There are a bunch of different options out there for this. The TuneTap has both optical and 3.5mm to RCA outputs. I just dug one out recently because I'm playing around with ways to listen to podcasts.
IOGEAR TuneTap Wireless Receiver
I disabled signatures. -
It's atrocious.
There you go, a first-hand account. Thanks!
Wow. There are options, I think the HK would best the Yammy if I can find one though either would work for her. One requires a phono preamp and the other a wireless dongle or device.Living Room
Office
one is -- deeply -- skeptical of that gizmo... but, yeah, it does have a phono preamp (presumably solid state -- not quite enough small signal tubes unless gain is low, methinks) and it does have Bluetooth. And, to its credit, it does seem to be a push-pull EL84 stereo amplifier, good for about 10 wpc.
It just kind of bugs me that the front panel (and general cosmetic vibe) is identical to the infamous "Nobsound" hybrid (sold under a fistful of names) of a few years back.
http://audiokarma.org/forums/index.php?threads/monoprice-pure-tube-amp.803027/
Yamaha R S303 on Amazon for $253
If you can find a unit with Bluetooth, it might just be worth it to buy her a newer turntable with built in phono. You'll likely need to invest some in that Sony.
As for speakers, I have some S15 and S20 for sale that might fit the bill.
The 15s could be an option. She is set on using the turntable but I want to avoid a rabbit hole at my expense.Living Room
Office
This unit is slightly above budget but checks all the boxes.
Living Room
Office
