Parasound Halo A21 or A23
kevhed72
Either color...if you are thinking about moving to a different amp, keep me in mind. Thanks
I would love a Halo A21 too. Kev, if you get more than one offer, send the seller you don't purchase from my way.
I have a 3 month old A23 in black that has about 50 hours on it that's in mint like new condition. I'm just waiting on a B&K amp to arrive before putting it on the block."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
I have a black Parasound A21 that I will be selling. Purchased in December of 2016 from a local authorized dealer. I have the original box and manual. Need to do some research and see what the going rate for these are. I would rate it as 9/10 due to it being used but otherwise in excellent condition. Shipping this will be pricey though.2 Channel
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90
Amps: Buckeye NC502
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
I have both A21 and A23's. Don't settle for the A23. The A21 is beast mode and will make your SDA's sing.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Good luck with your search. I use to have two A21's bi-amping my SRS-2.3s. The system sounded great. I had the matching Halo pre-processor and an A52 for my center and rear channels.
The silver stack is long gone, I miss it! Ten years ago:
Carl -
We called that a bow down to the bling cabinet. No Mr. T starter set here, man. The real deal, looks AND performance...Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Wow Carl, why on earth would you ever get rid of such a beautiful stack of gear???? DROOL!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Mikey081057 wrote: »I have both A21 and A23's. Don't settle for the A23. The A21 is beast mode and will make your SDA's sing.
I concur. I had the A23 for a bit before splurging for the A21. Huge performance difference, especially if your speakers prefer lots of juice. Very large and heavy though so make sure you have the space.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
dragon1952 wrote: »Mikey081057 wrote: »I have both A21 and A23's. Don't settle for the A23. The A21 is beast mode and will make your SDA's sing.
And a strong back!My New Year's resolution is 3840 × 2160
