Monitor 7B's fuse holder
I recently pulled my old pair of Monitor 7s out of the garage, got a vintage amp & receiver for Christmas, going back to analog. The speakers work fine after all these years but for one issue. The left speaker cuts out (not completely, just muffles and loses high end) sometimes. If I turn the fuse in the fuse holder it will kick back in. Bad connection somewhere on that fuse holder, just corrosion maybe? Gonna try and clean it up in the morning, but any advice would be appreciated :).
    pitdogg2 Posts: 27,064
    Clean contact points real well with stiff brush. Sometimes the wire leading to it corrodes so also check that.
  • machone
    machone Posts: 1,559
    Check the internal wiring. My 1A's wires were full of green corrosion. I ended up bypassing the fuses.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    F1nut Posts: 51,788
    7B fuse holder internal wires.....'nuff said.
