Speaker wire or jumpers
Looking to see if anyone has or knows where to get a couple feet of nice wire or spade/spade jumpers to go with the Usher CP-6311's. I'd like to stay budget friendly.
Thanks!
    pitdogg2 Posts: 27,040
    For my speakers I went to advanced auto/autozone bought some crimp on gold plated rings. Just a short piece of speaker wire and Walla. You could use spades to i just didn't have any so the ring terminals worked
  • dkfreebird
    dkfreebird Posts: 1,186
    edited December 2017
    I have a set that @pumpkinman gave away a little while back. They are 10" Linn k-400 wire with gold plated spades if you want them.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • dkfreebird
    Oppo 103
    Pangea PC
  • daboyz
    daboyz Posts: 5,207
    Pm me your wants or needs to get it done. Thanks
  • dkfreebird
    Just pm me your address and I will send them your way. :)
    Oppo 103
    Pangea PC
  • ken brydson
    ken brydson Posts: 9,002
    dkfreebird wrote: »
    AWESOME!!
    tonyb Posts: 33,072
    daboyz wrote: »
    Thanks!
    IMHO....you want jumpers of the same quality or better than the speaker cables your using.
  • daboyz
    daboyz Posts: 5,207
    Not disagreeing. We don't want to start a cable argument, do we? :smile: Checking with skip right now on some.
    tonyb Posts: 33,072
    Wasn't looking to start any arguments, just posting an opinion because I want to see you get the most you can out of the Ushers.
