New Rack
machone
I finally got around to a new rack. I built the old wooden back in 85.
I bought a VTI BLG503 with an extra shelf. After a temporary setup I was concerned the glass shelving ringing. I knew this might be an issue but I love the way the black glass looks. So I bought some 3/4" thick mdf and made shelving to go under the glass. I sealed the edges, sanded and sanded and painted them black using oil based paint. Now the shelves are dead with no ringing. I also filled the legs with sand and applied green Loctite any loose caps. I added strips of Dynamat to the steel shelf supports.
The results are outstanding both in looks and acoustically!
In addition I bought a new 65" Sony for the family and moved the 60" to the cave.
Check it out!
Check it out!
1KVA Dreadnought
Marantz SA 8005
Sony PS4
1KVA Dreadnought
Marantz SA 8005
Sony PS4
You know you're in deep when You are Dynamatting shelving.
That room looks awesome. I wish i could get my ears in there. -
Sweet looking ....really nice, congrats.HT SYSTEM-
lsi 9's -
Maaan, that turned out nice! Looks stout.
I was considering something similar with MDF.
Can you detail the coating process a bit? Interested to know what you did to seal the edges, and the general process.
Nice job matching the cutouts, too. What did you use for those cuts?I disabled signatures. -
The MDF under the shelves really makes this look substantial, nice!
Did you bond the MDF to the glass with something? -
Thanks!
I cut the mdf rectangles with a table saw and cutouts with a jig saw using a Bosch T101A0 blade (20tpi).
I then sanded all surfaces with 220 grit.
Next using your finger coat the edges with drywall mud. Then sand the edges with 320 grit. They need to be sanded very smooth!
I used an oil based semi-gloss black paint using a foam roller for smooth surfaces.
Once dry sand all surfaces again with 320 grit and apply another coat.
This is a far as I needed to go using glass on top. Even with a foam roller designed for smooth surfaces you can still see the roller bumps/grain because the super smooth surface of the mdf shows everything. It looks good without the glass but spraying would be the best way to get a perfect finish if not using glass over the shelves.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Meant to ask, the pads mounted on the rails - are those hard rubber, or something more like Sorbothane?I disabled signatures.
Looking good.
I opened this thread thinking someone had plastic surgery and we might get to see pictures. :'(
Nice set-up, machone! Is this the one that has the well-thought-out electrical service run to it? I think I can see it behind the rack.
Very nice.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Great job on the rack and an equally great job on the room to put it. Kudos to you
Thanks!
It has been a journey..............Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Awwww...thought this was a boob job thread.
Nice work, your Rack, Gear and Room look Exceptional!
Nice Rack Dude!!!"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Thanks!Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Very nice! Your hard work paid off.
Fantastic work, taking a nice rack to begin with to a new level...
Great looking and nice touch on the matted frames. I've yet to see someone dynamat their cables haha.Don't take experimental gene therapies from known eugenicists.
Nice work!
I've used lead shot in the tubes of VTI racks. Very important to secure end caps as it's not fun if one comes off while moving rack.
I've also used foam pipe insulation that fit tightly in the tubes along with insulating cross braces.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
We were cleaning up at work I inherited a 1" thick piece of clear acrylic. I cut a couple of retangular pieces on my table saw using the Cardas Golden Ratio as a guide. I sanded the edges with 320 grit and added hemispherical silicone feet. One is under the Quantum Byte and one is under the Mojo power supply.
My system just keeps getting better. Everything matters.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Wow nice rack machone!!! sand works great for filling the legs, i made monitor stands filled with sand, but they got waay to heavy
. The black glass looks amazing and you found a great solution for the ringing. Really inspiring man.
What is the thickness of the glass you used? -
Agree, nice job! I'm assuming no alignment issues when putting together as another one of our members experienced?Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
The glass comes with the rack and is 10mm thick.
The alignment was not "perfect" but settled in perfectly when leveled and assembled with the weight of the sand filled legs, glass shelving and equipment.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
